Hs4 Breather Pipes
And again
, Jun 14 2020 01:21 PM
4 replies to this topic
Posted 14 June 2020 - 01:21 PM
As per title could someone please point me in the right direction,do I connect the tappet breather to air filter and carb using a t piece or similar or do the route somewhere else see pics It’s my 1979 850
Posted 14 June 2020 - 01:55 PM
Just route it directly to the carb connection you pictured
Posted 14 June 2020 - 03:23 PM
Thanks for that wil do what about air filter do you just fit blank?
Posted 14 June 2020 - 06:00 PM
That hose connection point on the air filter was always unused and open on all the cars I've seen. It may had a hose connected there on something with an A series but I don't know what.
As Cal844 says just route it straight to the carburettor. For ease use the correct hose with the right sized ends.
Posted 14 June 2020 - 06:25 PM
Also check you have a Vented Oil Filler Cap fitted,
