Help Debugging Wiring - Lights
Best Answer cal844 , 14 June 2020 - 03:17 PM
Hi Cal;
checking brown wire to fuse box - think i have found the wire - testing resitance there is a brown wire not connected to starter
does this just connect to same connection as main battery feed ?
I believe it does, I'd try just running another wire from the loom connector at the starter upto the fusebox, if everything then works you've found your fault Go to the full post
4 replies to this topic
#1 MiniFanGraham
MiniFanGraham
  • 111 posts
Posted 14 June 2020 - 02:43 PM
Hi
Problem i have is headlights and dash light not working
hazards work
indicators work
ignition light on dash works (new centre console)
indicator dash light works
tested all fuses - all ok
tested light switch - works
but getting no power to switch
no power to brown wire at fuse box -which im guessing is first thing to resolve
any suggestions on where to test next ? (i'm no electrical genius)
thank you
#2 cal844
cal844
  • 9,624 posts
  • Local Club: TFMOC
Posted 14 June 2020 - 03:12 PM
Make sure there is continuity in and out of both switch and stalk.
Check the fuses and earths too, make sure brown wire connections are clean and tight.
What year of car?
Edited by cal844, 14 June 2020 - 03:15 PM.
#3 MiniFanGraham
MiniFanGraham
  • 111 posts
Posted 14 June 2020 - 03:15 PM
Hi Cal;
#4 cal844
cal844
  • 9,624 posts
  • Local Club: TFMOC
Posted 14 June 2020 - 03:17 PM   Best Answer
Hi Cal;
#5 MiniFanGraham
MiniFanGraham
  • 111 posts
Posted 14 June 2020 - 06:27 PM
Cheers Cal for the confirmation; once again your correct
I now have lights :)
