Bonnet Gap
6 replies to this topic
#1 AlasdairM
AlasdairM
  • 240 posts
Posted 17 June 2020 - 02:38 PM
Hi folks
Now that my car is roadworthy, I’ll start to address the problems which aren’t so critical.
As pictured, the bonnet doesn’t sit that well. I think it could do with going back 5mm or so towards the windscreen.
It’s a new bonnet, there’s a foam strip below the back of the bonnet, and there is a rubber water seal at the front of the bonnet above the grille.
Any tips?
#2 AlasdairM
AlasdairM
  • 240 posts
Posted 17 June 2020 - 02:39 PM
Again sorry for the rotated images, but I’ll blame the iPhone!
#3 Bobbins
Bobbins
  • 1,500 posts
Posted 17 June 2020 - 02:58 PM
There's 4 nuts anchoring the bonnet to it's hinges, loosen them and the bonnet will move around a little, then re-tighten. It'll probably take a few attempts before you get it where you want but you should be able to get it a lot better.
#4 humph
humph
    How bad can it Be?
  • 1,103 posts
Posted 17 June 2020 - 03:05 PM
I have the same issue, but don't seem to be able to get it completely right.
As Bobbins says it's easily adjusted, but take care, use at least two people.  What I've done is put a couple of layers of masking tape on the scuttle panel to avoid damaging the paint with the bonnet. This is where my problem has been, adjust it so the gaps look right and it catches the scuttle when you open it, sort this and the gap looks to big!  Watch that paint though.
#5 sonikk4
sonikk4
    Twisted Paint Polisher!!!
  • 16,053 posts
  • Name: Neil
Posted 17 June 2020 - 04:10 PM
A tip with it touches the scuttle is to dress the edge of the bonnet rear lip in a bit. It can give you that extra couple of mm to make all the difference.
#6 AlasdairM
AlasdairM
  • 240 posts
Posted 17 June 2020 - 07:39 PM
Thanks.
Yes I was the one who fitted it, but I couldn’t get it to sit right when fitting the first time. I think it’s settled now and is sitting better, but definitely needs to go back a bit.
I’ll maybe try bending the rear lip as you say sonik
#7 sonikk4
sonikk4
  • 16,053 posts
  • Name: Neil
Posted 17 June 2020 - 07:59 PM
I did all sorts with mine on Paddy and that was a Heritage bonnet. Lots of tweaking here and there to get it sitting nice at the back. Just a shame at the front as its not really flat enough but i can live with that.
