Technique For Installing Lcb
11 replies to this topic
#1 Zami
Zami
  • 169 posts
Posted 18 June 2020 - 03:16 AM
Just picked up a stage II LCB and am trying to decide if I should just remove the head/carbs etc to get the old one out and to install the new one, or is there a technique to removing/installing without removing the head? I seem to recall someone describing the process but have been unable to locate the thread.
#2 nicklouse
  • 18,696 posts
Posted 18 June 2020 - 06:32 AM
No need to remove the head.
just remove the old manifolds and fit the new one.
#3 sonscar
sonscar
  • 3,046 posts
Posted 18 June 2020 - 07:14 AM
Take off the carb and manifold,undo the top engine steady and pull the motor away from the bulkhead.Fit new lcb with a twisting action.You may struggle for a while and then suddenly it will drop in and you will gaze in wonderment as to why it did not fit the first time.Have fun.Steve..
#4 Tomm
Tomm
  • 2,462 posts
Posted 18 June 2020 - 07:36 AM
Just to echo earlier comments. Head certainly doesn’t need to be removed. I’ve not done one for probably 10 years, but it can be done with everything in situ.
#5 nicklouse
  • 18,696 posts
Posted 18 June 2020 - 07:50 AM
Oh the outer in the hole first then the inner single one then attach to the head.
#6 Dannyboolahlah
Dannyboolahlah
  • 168 posts
Posted 18 June 2020 - 09:06 AM
The first time will take a lot of tea/beer and swearing...
By the 12th time it'll fly in.
#7 Spider
  • 15,136 posts
Posted 18 June 2020 - 10:05 AM
When I have fitted these, there was a few sets that I also need to undo the Engine Mount under the flywheel and slide the engine forward as for as it would go. The Australian made types are easier to fit.
#8 panky
panky
  • 1,792 posts
Posted 18 June 2020 - 10:15 AM
I replaced the manifold studs with bolts, so you don't need to lever the engine forward to remove the manifold.
#9 charliefarlie37
charliefarlie37
  • 149 posts
Posted 18 June 2020 - 11:56 AM
Lots of swearing helped me ?
#10 mini-mad-mark
mini-mad-mark
  • 863 posts
  • Local Club: northants wot no brakes
Posted 18 June 2020 - 05:58 PM
I haven't done it for a while and +1 for loosening engine steady/ies but....
IIRC its a bit counter-intuitive that you put the outer part in with the exit facing the diff and then turn it towards the head when the exit gets below the subframe rail
(Thinking about it I guess this works due to the shape of the down pipe and going the other way makes it hit the bulkhead but as I say not done it for a while)
The single inner goes in easily (Again IIRC)
#11 Mini Manannán
Mini Manannán
  • 2,860 posts
  • Local Club: man Estate
Posted 18 June 2020 - 09:49 PM
The newer the paintwork the more difficult it is :-)
#12 Zami
Zami
  • 169 posts
Posted 18 June 2020 - 09:52 PM
As soon as I get it back from ceramic coating I’ll give some of your recommendations a try. Thanks to all.
