K&N Filter and needle
5 replies to this topic
#1 Awlred Drives a Quant
  • 145 posts
  • Local Club: Tyred and Exhausted
Posted 29 October 2006 - 08:20 AM
What needle should I use with this filter [clicky] because I haven't got a clue.
Its a HS4 single carb on a 998 Lump.
cheers
Edited by Awlred Drives a Quant, 29 October 2006 - 08:22 AM.
#2 THE ANORAK
THE ANORAK
  • 3,946 posts
Posted 29 October 2006 - 08:57 AM
this is the type that i have, and always use the standard needle :P
would be interesting to know what i should be doing :genius:
#3 Big_Adam
Big_Adam
  • 7,435 posts
Posted 29 October 2006 - 10:23 AM
well for the cone i left it as is.
for a 998 tho a cone is slightly better as the elbow joint has a bit of restriction to it, but there is less induction noise.
but you'll be ok with the stock needle just need to rich the mix a little.
Edited by Big_Adam, 29 October 2006 - 10:28 AM.
#4 Awlred Drives a Quant
  • 145 posts
Posted 29 October 2006 - 06:05 PM
I was put off the cone because I heard that without the airbox there is a good bit more noise from the carb, which I'm not gaint on loud noises, means I have to put my stereo up wich means my missus complains more ;-) and I heard that the airbox filters from K&N are almost as good as the cone/pancakes that are available.
#5 mike998
mike998
  • 328 posts
Posted 29 October 2006 - 06:16 PM
i have a cone filter on mine and it doesnt sound any louder, it just hisses at you when ever you floor it. you just get a little better airflow.
#6 Big_Adam
Big_Adam
  • 7,435 posts
Posted 29 October 2006 - 06:37 PM
yeah, the inducion hiss is a little much. stick some holes in the air box tho, help aid to the perfomance. just sounds nice and with no hissin sound.
