Mark 1 Mini Rear Problems
5 replies to this topic
#1 Darnikki
Darnikki
    Starting My Mini Up
  • 1 posts
Posted 08 July 2020 - 09:44 AM
Having renovated 1963 mini to excellent spec I have found that the rear window was replaced 1980,s to Mk2 window due to rust
Do I replace with smaller window or leave as it is and what would be the case if I decide to sell
many thanks for your thoughts in this matter
#2 Homersimpson
Homersimpson
  • 831 posts
Posted 08 July 2020 - 11:05 AM
I would say it depends on how far along you are with the rebuild, if its finished and painted I wouldn't bother but if your still at the bodywork stage then I would look to change it back.
Are you sure its a MK1 shell and not a MK2?  At that age it should have a floor start and the rear side windows are different if I remember correctly.
#3 Tupers
Tupers
  • 4,154 posts
Posted 08 July 2020 - 11:12 AM
It will definitely effect the value if and when you come to sell it.
If it’s a nonstandard car then it wouldn’t be so bad but if you have the opportunity to charge it you probably should.
#4 gazza82
gazza82
  • 3,017 posts
  • Local Club: TMF+
Posted 08 July 2020 - 11:19 AM
Assuming any potential buyer realises! :shifty:
#5 DB1380
DB1380
  • Just Joined
  • 55 posts
Posted 08 July 2020 - 02:41 PM
How have they fitted the bigger mk2 rear screen ? It may have had a Shunt up the rear end many moons ago and they then fitted a complete mk2 rear panel ?
#6 mab01uk
mab01uk
  • 12,462 posts
Posted 08 July 2020 - 03:32 PM
It was not unusual back in the day to fit a Mk2 rear panel and window to a Mk1 which had been rear ended, maybe leave it as is and it is just part of the cars 'real' history. The cost of changing it may also be more than any extra value added depending how the figures add up and who does the work/parts/labour involved.
The new Mk1 Heritage bodyshells are modified to reduce the Mk2 onwards rear window size but not sure if they sell the small panels used seperately?
Watch from 3mins 35sec into BMH video below:-
Edited by mab01uk, 08 July 2020 - 03:41 PM.
