Wheel Alignment
1 reply to this topic
#1 geepeetee
geepeetee
  • 49 posts
Posted 20 July 2020 - 07:48 AM
Hi
I have our 92 Open Classic about ready for the MOT after 9 years laid up / ongoing restoration. Both front / rear suspension, steering and drivshafts have been stripped and rebuilt. The rear subframe has also been off, refurbished and refitted.
Prior to taking it for MOT and tracking check i wanted to chec rear wheel alignment. I found an article suggesting passing a loop of string around the càr through all 4 wheel centres and measuring toe in/out on the rear wheels.
Ive done this and both toe in, drivers side is 6mm and passenger side is 2mm. Thoughts on this appreciated.
I understand shims can be fiited to adjust. Is either correct? How critical are the rear? Or do they just need to be the same?
Thanks in advance
Gary
#2 Chris1275gt
Chris1275gt
  • 957 posts
Posted 20 July 2020 - 12:41 PM
Hi
Thanks in advance
Gary
Hi Gary have a read of this.
https://www.calverst...-set-up-method/
