Resistor Plugs Vs Non
2 replies to this topic
#1 croc7
croc7
  • 814 posts
Posted 05 August 2020 - 06:23 AM
Which plug to use? Resistor or non? I’ve been told that the use of resistor plug helps reduce the effect of EMF on electronic ignition systems. I’ve used both and haven’t noticed a difference on the old ‘butt Dyno’. Thoughts?
#2 hazpalmer14
hazpalmer14
  • 684 posts
  • Local Club: cumbria mini cruisers
Posted 05 August 2020 - 07:53 AM
I think it depends on the ignition system you have and what leads you have. I cant remember off the top of my head. I use megajolt on my mini and I use resistor plugs
#3 sonscar
sonscar
  • 3,024 posts
Posted 05 August 2020 - 08:40 AM
Not a Mini but similar an MGB.I use Megasquirt on this and resistor plugs are a must.Non resistor causes resets and RPM spikes.Electronic ign suppliers should give advice.Steve..
