Can Not Get Flywheel Off...
18 replies to this topic
#1 henrietn
henrietn
    Just On Tickover
  • 8 posts
Posted 05 August 2020 - 05:07 PM
hi guys, this is my first mini. year 1985 which I am restoring.
I got a 1275 A+ engine, which developed an issue (probably a spun crank bearing)
I need to get the flywheel off, but for the love of god, I just can not get it off. I bought the beefy mini flywheel remove kit, and welded a jiog to hold the flywheel in place, but even the beefier kit was bending
Do i have more options? or do I need to cut the pressure plate, making sure I dont hit the crank.
#2 PoolGuy
PoolGuy
  • 975 posts
Posted 05 August 2020 - 05:34 PM
Have you whacked the puller with a big hammer?
#3 henrietn
henrietn
    Just On Tickover
  • 8 posts
Posted 05 August 2020 - 05:35 PM
hey, thx for the reply. yes, i gave it some very hard hits with the hammer, nothing. Also tried some heat. it just ist moving
#4 alex-95
alex-95
    I am THE CLAMP MAKER
  • 6,078 posts
Posted 05 August 2020 - 05:37 PM
How long did you leave the puller on? Turn the flywheel so the slot is horizontal as not doing this can cause problems getting it off.
#5 henrietn
henrietn
    Just On Tickover
  • 8 posts
Posted 05 August 2020 - 05:56 PM
you mean the slot on the crank? i can give that a go. I left the puller on for 2 days
#6 nicklouse
  • 18,998 posts
Posted 05 August 2020 - 05:57 PM
slots horizontal.
lock flywheel in place.
get some proper washers.
lubricate the drive bolt threads.
make sure the plate is Parallel to the flywheel.
apply force to bolt.
leave come back apply force. have tea apply force. watch some TV apply force. go to bed. get up apply force. have breakfast apply force you get the idea.
#7 steeley
steeley
  • Just Joined
  • 623 posts
Posted 05 August 2020 - 05:59 PM
Have the slot horizontal as above to make sure primary c washer
does not lock it all up when you try and pull it
Spray it with gt85 leave overnight and then whack puller with lump hammer
#8 henrietn
henrietn
    Just On Tickover
  • 8 posts
Posted 05 August 2020 - 06:01 PM
i will try that horizontal. Didn't really think about that to be honest.
thx guys!
#9 alex-95
alex-95
  • 6,078 posts
Yep. Theres not much else you can do really, as said above make sure the plate is parallel to the flywheel and try some thicker washers. A guessworks puller may help as that is even more heavy duty than the one you have and also doesn't have slots all the way down which weakens it .
#10 Pete649
Pete649
  • 381 posts
Posted 05 August 2020 - 06:27 PM
When it does finally let go it can release suddenly and with some force. Might need to move your feet out of the way sharpish :-)
#11 nicklouse
  • 18,998 posts
Posted 05 August 2020 - 06:38 PM
a bit of GuessWorks pully action
and the man in action himself
https://youtu.be/uzLZhPGdpyE
#12 sonikk4
sonikk4
    Twisted Paint Polisher!!!
  • 16,168 posts
  • Name: Neil
Posted 05 August 2020 - 07:06 PM
As mentioned some thicker washers to start with, wind on the pressure, heat it, then shock it with freeze spray. Worked for me.
#13 GraemeC
GraemeC
  • 7,467 posts
Posted 05 August 2020 - 07:26 PM
This won’t help you get the flywheel off, but might save pain later........ the end of the main puller bolt looks a bit marred - is there something to protect the end of the crank?
When you replace those washers with thicker ones, use the thin ones on the wok bolts you have wound back in - 3 or 4 evenly spaced around the circle. These will catch the flywheel when it eventually springs off.
Edited by GraemeC, 05 August 2020 - 07:29 PM.
#14 blacktulip
blacktulip
  • 6,231 posts
Posted 05 August 2020 - 08:40 PM
I had a similar issue a few months ago and I finally got it off by hitting the fly through the starter motor hole with my big breaker bar like a snooker cue. It seemed so easy this way I vowed to try again if there is a next time.
#15 henrietn
henrietn
    Just On Tickover
  • 8 posts
Posted 05 August 2020 - 09:55 PM
thx for the tip !
