weird question so please bear with me!
i've never managed to get the brakes on my mini so they actually work on the first pump of the pedal.
i've recently rebuilt it with new rear brakes and it has cooper S discs on the front (it's a 1960 model so these were replaced). i've bled them throughly and there is not air in the expelled fluid. i've used both a vacuum pump and the two man method and put a whole bottle of fluid through to no avail. they work great but only after a second pump of the pedal.
the rear drums are adjusted so that i can get 3 clicks (may 4 at a push) on the handbrake. the master cylinder is original type but it looks like the cooper S master cylinder is the same bore size (0.7") anyway with just a larger reservoir.
clearly i've bled brakes hundred of times before on other cars with no issues but no matter what i try the mini still has this issue.
what am i missing?
i'm wondering if perhaps the MC is actually a clutch MC with a narrower bore or something?
the hand brake is kinda an independant system, you may need to adjust the square brake adjuster on the back of the drums.
