Spax Vs Gaz
Posted 09 August 2020 - 01:18 PM
The question is which are preffered these days?
Posted 09 August 2020 - 01:44 PM
AVO.
Posted 09 August 2020 - 04:59 PM
Shooter
Posted 09 August 2020 - 05:36 PM
Posted 09 August 2020 - 05:41 PM
Are you sure you need them, as long as you arnt bottoming out the dampers on full compression you would be better running std length, the more droop you have the better the car will ride ie it won't drop into big dips in the road as the damper will still be working and not fully extended
Shooter
But the suspension could dislocate without shorter shocks to hold it all together.
Posted 09 August 2020 - 06:51 PM
I've always heard good references about AVO and the yellow/blue Bilsteins. The problem is that they are very expensive.
Regards
Posted 09 August 2020 - 07:20 PM
Protec or Spax, Gaz corrode within seconds.
Posted 09 August 2020 - 08:16 PM
Posted 09 August 2020 - 08:34 PM
Would anyone be able to suggest the length I will require? Going for 2 finger arch gap all round.
Posted 09 August 2020 - 08:38 PM
You are lowering the car so the lowered set.
Posted 09 August 2020 - 09:01 PM
FYI for anyone interested they work out a fair bit cheaper buying them from Huddersfield Mini spares.
Screenshot_20200809-215228_Chrome.jpg 21.63K 6 downloads Screenshot_20200809-215741_Chrome.jpg 22.96K 3 downloads
Posted 10 August 2020 - 07:26 AM
I bought a set of Protech shocks from Huddersfield Mini Spares, in a package that they did. I got Front and Rears shocks, quality ride height adjusters and knuckle joints, for about the same money as buying just the shocks from Protech.
To be honest I didn't use the knuckle joints, as I already had some quality ones in stock.
Posted 10 August 2020 - 10:28 AM
They were fitted on a car that was properly set up and corner weighted and I thought they were very good.-didn’t drive it on salted roads in the winter so I can’t comment on corrosion.
Edited by and90cooper, 11 August 2020 - 07:11 AM.
Posted 10 August 2020 - 01:09 PM
Posted 10 August 2020 - 08:21 PM
To summarise for anyone searching for an answer, I found most prefer either Spax gaz or Protech, and if lowering at all go for lowered shocks.
