Fuel Tank Hose
8 replies to this topic
#1 JJKM
JJKM
    Just On Tickover
  • 5 posts
Posted 10 August 2020 - 10:11 PM
Hi all,
I've just removed my petrol tank to clean out all the crud (there was a lot!) and noticed that the preformed rubber hose/pipe that connects the tank to the rigid pipe is knackered. I can't seem to find this - does anyone have a part number or source?... Thanks
#2 Chris1275gt
Chris1275gt
  • 958 posts
Posted 10 August 2020 - 10:37 PM
Or you can get it off eBay where postage will probably be cheaper.
#3 JJKM
JJKM
    Just On Tickover
  • 5 posts
Posted 14 August 2020 - 09:22 AM
Thanks for your reply. The one I'm replacing is a shaped hose, rather than a standard piece. I was concerned using normal hose will kink and stop the flow?
#4 Chris1275gt
Chris1275gt
  • 958 posts
Posted 14 August 2020 - 09:31 AM
I'm not certain but if it's an old bit of pipe over time it has probably lost its flexibility and assumed a semi rigid state. When replacing it you will probably have to put it at a very severe angle to actually kink it.
#5 whistler
whistler
  • 1,815 posts
Posted 14 August 2020 - 10:05 AM
https://www.ebay.co....6-/152816125698
#6 peterh2
peterh2
  • 44 posts
Posted 14 August 2020 - 10:54 AM
I would be carful with any old stock fuel pipe. It probably won't be ethanol proof. It's well know that ethanol in modern petrol will attack rubber hoses. There have been several car fires attributed to hoses leaking as a result.
#7 cal844
cal844
  • 9,632 posts
  • Local Club: TFMOC
Posted 14 August 2020 - 09:49 PM
I'd just use normal fuel hose, make sure you know when it was made though!
#8 JJKM
JJKM
    Just On Tickover
  • 5 posts
Posted 14 August 2020 - 09:51 PM
Thanks, @whistler - that's the one I was after.
#9 JJKM
JJKM
    Just On Tickover
  • 5 posts
Posted 14 August 2020 - 09:52 PM
And thanks for the advice on hose from everyone else ??
