Was wondering if someone could clarify a possible misunderstanding on my part as while aware the Mini’s engine bay is notoriously a very tight squeeze, am rather perplexed by the following that suggests an end-on gearbox mated to an A-Series was feasible.
- On the Austin Memories article about the Minki, it was mentioned a Maestro A-Series and Volkswagen-sourced gearbox was attempted in the Mini though was too tight with the A-Series 4-cylinder engine being roughly equivalent to a K-Series three and a half cylinder engine in length.
- It is then mentioned the subframe was 4-inches too narrow to accept the 4-cylinder K-Series engine and gearbox (possibly the PSA MA/Rover R65), leading to 3-cylinder version being created (as each K-Series cylinder was around 4-inches) that reputedly used the same Volkswagen-sourced gearbox from the Maestro (unless Minki I also used the PSA MA/Rover R65 gearbox).
- The later Minki 2 had its wheelbase and width increased by 50mm / 2-inches in order to fit the 1.4 4-cylinder K-Series and PSA MA/Rover R65 gearbox from the Metro/100.
For those who have done K-Series Mini conversions and other engine replacements/swaps, would it have been theoretically possible for an A-Series mated to PSA MA/Rover R65 gearbox or some other compact / earlier equivalent gearbox to viably fit into the Mini’s engine bay without needing to have its wheelbase and width increased to around 50mm like on the Minki 2?
