Twin Su Carbs
Best Answer steeley , 16 August 2020 - 06:01 AM
Not a lot of benefit apart from looking cool then
I think I’ll still get and fit a set though Go to the full post
21 replies to this topic
#1 steeley
steeley
  • Just Joined
  • 623 posts
Posted 15 August 2020 - 09:13 AM
I have a 998 I have almost finished rebuilding
It’s a std setup at the moment but just thinking for the future
Is there any major benefit to running a twin carb set up if so hs2 or hs4?
#2 cal844
cal844
  • 9,645 posts
  • Local Club: TFMOC
Posted 15 August 2020 - 09:19 AM
If its standard just fit a single hs4, it'll be easier to tune and get running well.
In regards to twin carbs what you gain top end you lose in low end. Throttle response may be slightly better though.
#3 GraemeC
GraemeC
  • 7,440 posts
Posted 15 August 2020 - 09:21 AM
Certainly use no more than twin HS2 on a 998.
Benefits - possibly better throttle response, but not much else other than looks and pub points.  Obviously more expensive to put in (refurb costs are double for instance) and will need to be set up well.
For a road car and weekend play toy, a single HS4 or HIF38 would be the sensible choice
#4 steeley
steeley
  • Just Joined
  • 623 posts
Posted 15 August 2020 - 10:11 AM
Maybe I’ll stick with the hs4 that’s on it
I just like the look of the twins
#5 johnv
johnv
  • 498 posts
  • Local Club: FDMC
Posted 15 August 2020 - 12:37 PM
Then go with twins. You're not running an old mini for practical reasons ;)
#6 johnR
johnR
  • 2,302 posts
Posted 15 August 2020 - 03:53 PM
I'd spend the money on an RC40 exhaust and a slightly lighter flywheel - transformed my 998 on a single HS4. Having said that I do like the look of twins!
Edited by johnR, 15 August 2020 - 03:55 PM.
#7 nicklouse
  • 18,697 posts
Posted 15 August 2020 - 03:58 PM
pointless waste of money.
#8 johnv
johnv
  • 498 posts
  • Local Club: FDMC
Posted 15 August 2020 - 04:31 PM
If your only aim is efficency.
#9 Minigman
Minigman
  • 779 posts
Posted 15 August 2020 - 06:07 PM
Go for it and fit the HS2s they are better low down than a single carb. And they’re cool. Once set up they run ok and if they’re in good condition don’t go out if tune. I’m a twin carb fan as you can tell.
Edited by Minigman, 15 August 2020 - 06:07 PM.
#10 petey81
petey81
  • 1,341 posts
Posted 15 August 2020 - 10:05 PM
Im a big twin su fan as well! Its your car so go for it. You will get haters ??
#11 steeley
steeley
  • Just Joined
  • 623 posts
Posted 16 August 2020 - 06:01 AM   Best Answer
Edited by steeley, 16 August 2020 - 10:06 AM.
#12 johnR
johnR
  • 2,302 posts
Posted 16 August 2020 - 08:42 AM
I don't think there's any contest in the looks department!
#13 Minigman
Minigman
  • 779 posts
Posted 16 August 2020 - 08:46 AM
I’m in Bournemouth anyone know anyone near me who would set them up properly
They do work well low down and give better throttle response than a single. That’s why BMC fitted them in the first place on the 997 Cooper instead of a H4/HS4 single.
Not sure about Bournemouth but Stephen Miles of Tipton Garage in Ottery St Mary are a good bet for set up and rolling road prep. So set them up as per the instructions on Burlen website. Then get the car to Titpons. If your engine isn’t yet in I’d seriously consider changing the cam at this point. The head can be done later whilst the engine is in the car but the cam is far more tricky once in.
Edited by Minigman, 16 August 2020 - 08:49 AM.
#14 johnR
johnR
  • 2,302 posts
Posted 16 August 2020 - 11:23 AM
It's quite expensive to re-furb a set of twins - especially if they need re-bushing. The kit of jets, spindles and gaskets is is @ £80 and I think a re-bush was £60 per carb when I looked into it (Burlen). Add to this the cost of having the alloy parts vapour blasted and other parts re-plated and it all adds up.
#15 steeley
steeley
  • Just Joined
  • 623 posts
Posted 19 August 2020 - 07:45 PM
Looking around for a set, lots of different types - aud69 ,aud327 etc listing for mini and mg etc what would be the best type to buy for a std 998
Edited by steeley, 19 August 2020 - 08:39 PM.
