Cv Joint : Can't Get It Onto The Drive Shaft
11 replies to this topic
#1 Elwyn
Elwyn
  • Just Joined
  • 365 posts
Posted 16 August 2020 - 03:51 PM
Hello
I've replaced the old cv joints with new from mini spares
I can get the new cv joint to align with the splines
Enough to turn the driveshaft so I know it's engaging
I've pushed, hit with a rubber mallet, hit with a hammer to the end of the cv joint with the old not screwed onto the end
It won't budge
It just drops off the end of the drive shaft as soon as I stop pushing or hammering and let go
Any ideas?
Edited by Elwyn, 16 August 2020 - 03:51 PM.
#2 RustyAutoCityE
RustyAutoCityE
  • 320 posts
Posted 16 August 2020 - 04:31 PM
Have you checked if the circlip is still in the right place and intact in the end of the driveshaft?
#3 Elwyn
Elwyn
  • Just Joined
  • 365 posts
Posted 16 August 2020 - 05:34 PM
Yes, it starts off in place but gets mawled, bent and moved out of place as I try to get the CV joint over and around it
#4 Chris1275gt
Chris1275gt
  • 965 posts
Posted 16 August 2020 - 06:39 PM
Theirs a thick and a thin circlip have you got the right one on the inboard shaft it's the thin one I think.
#5 Elwyn
Elwyn
  • Just Joined
  • 365 posts
Posted 17 August 2020 - 07:48 AM
Yes, both the right ones
#6 cian
cian
  • 869 posts
  • Local Club: Minis In Northern Ireland
Posted 18 August 2020 - 06:10 AM
Put the cv is a soft vice clean the driveshaft up of grease and put the shaft in that way, you will see more what’s going on
#7 Chris1275gt
Chris1275gt
  • 965 posts
Posted 18 August 2020 - 09:58 AM
As above I'd also remove the circlip first to check it slides into the cv Joint.
#8 johnR
johnR
  • 2,302 posts
Posted 18 August 2020 - 10:41 AM
As Cian says, put the CV joint in a workmate or similar in good light - the issue will be the circlips need to be compressed to fit in. I've just done one and I found the way to do it is to push the shaft into the joint up to the circlip, then use a small screwdriver to push the clip ends into their slot in the shaft, lean the shaft a little to lock them in the groove then push the rest of the clip into the groove whilst keeping pressure on the shaft so it doesn't spring out again. hope this makes sense and helps.
#9 xrocketengineer
xrocketengineer
    Rocket Man
  • 1,637 posts
Posted 20 August 2020 - 03:44 PM
It also helps to use a dab of thick grease to hold the circlip centered and concentric with the groove, so it does not droop down with gravity during installation and gets pinched.
#10 Elwyn
Elwyn
  • Just Joined
  • 365 posts
Posted 02 September 2020 - 01:00 PM
Thanks all
That outer circlip is a fiddly b*gger
It certainly doesn't want to stay in place
What does it do anyway?
Other than annoy me?!
#11 sonscar
sonscar
  • 3,037 posts
Posted 02 September 2020 - 01:03 PM
It helps to keep the driveshaft in the hub.Steve..
#12 Tornado99
Tornado99
  • 750 posts
Posted 02 September 2020 - 03:08 PM
Had similar issue with circlip not permitting cv to fully slide over. Took clip off and did a little bending to make it fit the shaft groove tighter. CV went right on just fine afterwards.
