Edited by Elwyn, 17 August 2020 - 12:15 PM.
Hilo's, Springs And Shocks
Posted 17 August 2020 - 12:14 PM
Posted 17 August 2020 - 03:22 PM
compress the shock to fit.
Posted 17 August 2020 - 03:29 PM
You're slipping Nick - where's the library of failed coil spring pics?
Posted 17 August 2020 - 04:11 PM
Coils have not been mentioned yet. Rubbers are still springs.
Posted 17 August 2020 - 04:27 PM
.......spring, cone replacement kitReferences from P&L Minis, Rotherham :PL-SSK
https://www.plminish..._Sheffield.html
Edited by GraemeC, 17 August 2020 - 04:27 PM.
Posted 17 August 2020 - 07:34 PM
well then in that case
have fun they are not fit for purpose unless your car is a trailer queen.
there is not enough movement available in the coil springs so the bind and then something will fail.
Posted 19 August 2020 - 09:39 PM
Posted 21 August 2020 - 02:04 PM
B*ll*cks to b*ggery
What's the failure rate?
All of them?
I've only fitted one so far
Not gone too far to switch to cones
Posted 21 August 2020 - 02:07 PM
Ok, so which cones are best for normal road driving?
Not lowered, never going off road with it
Quite keen on my vertebrae not being hammered into each other
Red spot?
Posted 21 August 2020 - 02:45 PM
Posted 21 August 2020 - 03:24 PM
Standard rubbers with HiLos (genuine) will be best.Ok, so which cones are best for normal road driving?
Red spot?
Failure rate of coils unknown but as they all have the possibility of going coil bound it is higher. The reason they go coil bound is there is not sufficient space between the coils for them to compress before the suspension has gone through its motion. this means the coils touch each other before the bump stop has taken some of the load. Used to happen a lot on early full suspension when people changed the springs not understanding what they were doing. An exploding coil spring next to your calf does hurt.
Posted 21 August 2020 - 04:14 PM
Love the pics I followed your advice a while ago and sold my Minitastic Springs, this always raises discussions every time
Edited by I hate Brian, 21 August 2020 - 04:15 PM.
Posted 24 August 2020 - 03:46 PM
For the original question, is it not just a matter of compressing the shock to get it on the perch? There should be some preloading on the shock, even with wheel off ground.
