Removing 1.5 Roller Rockers
27 replies to this topic
#1 64mini
64mini
    Just On Tickover
  • Just Joined
  • 5 posts
Posted 21 August 2020 - 11:23 AM
Hi all
Im looking to improve idle and road manners. The engine has provided me with fun for quite a few years. My young son has taken a liking for weekend drives in the mini so i would like to calm things down a bit
1380
1.5 rollers
Ported head
Mini sport ca4 cam ( i believe its close to a 286 correct if im wrong)
Twin hs4
Lcb...
Is it a straight swap if i replace the 1.5 rocker with standard pressed type or 1.3 rollers? Or does it effect cam timing? Will it improve idle or lower the rev range a little to a noticeable level anyway?
I am looking at pulling the engine and changing cams in the future but i thought dumping the 1.5's is something i could do to improve things a little whist saving my pennies?
#2 nicklouse
  • 18,998 posts
Posted 21 August 2020 - 12:10 PM
Changing down to 1.3 or standard will do as you want.
Improve the torque in the lower end and make it a bit more drivable.
#3 64mini
64mini
    Just On Tickover
  • Just Joined
  • 5 posts
Posted 21 August 2020 - 12:38 PM
Thanks. Can i change them straight over? Best to replace the head gasket i assume?
#4 nicklouse
  • 18,998 posts
Posted 21 August 2020 - 01:53 PM
Many people have changed rockers without needing to change the head gasket.
Myself many times.
#5 DB1380
DB1380
  • Just Joined
  • 55 posts
Posted 23 August 2020 - 07:59 PM
Just make sure you drain the Coolant if you swap the Rockers without doing the HG. If you dont drain it, theres a very good chance you will get water seeping where you Dont want it.
Dicky.
#6 64mini
64mini
    Just On Tickover
  • Just Joined
  • 5 posts
Posted 23 August 2020 - 09:54 PM
Thanks for the tip. Now the hard part. Finding a standard rocker assembly that fit big bores. Might have to cough up for 1.3 rollers. Its a shame mini spares dont do standard rocker kits. I think they sell all the bits but im not 100% sure what i need for my engine.
#7 nicklouse
  • 18,998 posts
Posted 23 August 2020 - 10:31 PM
AC Dodd is reworking the standard ones at 1:1.3
#8 DB1380
DB1380
  • Just Joined
  • 55 posts
Posted 24 August 2020 - 04:12 PM
Im going to change my Rockers from 1.5 to 1.3s on my 1380. I will be getting mine from AC Dodd. Cant really find any others at the mo and ive heard ACs are very good.
#9 ACDodd
ACDodd
  • Mini Docs
  • 2,832 posts
Posted 24 August 2020 - 05:07 PM
Currently 1.28:1 on the shelf. 1.3:1 versions in the next 3 months.
Ac
#10 DB1380
DB1380
  • Just Joined
  • 55 posts
Posted 24 August 2020 - 06:38 PM
Ac
Cheers AC, i have just sent you a PM.
Dicky.
#11 JVA10L
JVA10L
  • 186 posts
Posted 24 August 2020 - 09:00 PM
I have just pulled my rocker shaft out without loosening the head nuts or the posts by taking out the pinch bolt and sliding the shaft out towards the clutch end. I had to slacken all the tappet adjusters and turn the engine till there was no load on any of the valves. It is a bit of a fiddle but possible and better than disturbing the head.
EDIT:
I've now realised this is not relevant to the original question because if you change the rocker ratio you have to change the posts as well. The hole centre is moved to suit the arm length.
I was taking mine out to change the push rods and cam followers.
Edited by JVA10L, 25 August 2020 - 06:33 PM.
#12 maccers
maccers
  • 1,880 posts
  • Local Club: LSMOC
Posted 25 August 2020 - 08:38 AM
MED still do 1.3 roller rockers - I got a set years ago and went to their website recently to check for any advice about what size feeler to use when setting the gap.
#13 DB1380
DB1380
  • Just Joined
  • 55 posts
Posted 31 August 2020 - 09:00 PM
Macc, ive just bought some 1.3s from MED and been told to set them at 0.015".
#14 maccers
maccers
  • 1,880 posts
  • Local Club: LSMOC
Posted 04 September 2020 - 12:43 PM
Cheers!! Will give it a go..
#15 DB1380
DB1380
  • Just Joined
  • 55 posts
Posted 05 September 2020 - 08:41 PM
Fitted my MED 1.3 Rockers this morning. They are superb quality, ready to go straight out the box. Set them to 0.015"- MED say 0.016".
Car drives better, idles better and its alot quieter...but i put that down to the old 1.5s being worn, they were 17yrs old !
Dicky.
