Best Spark Plugs For 45D Electronic Distributor?
6 replies to this topic
#1 psoutzis
psoutzis
  • 278 posts
Posted 24 August 2020 - 01:34 PM
As above, recently converted to electronic ignition and i need to change the spark plugs.
#2 cal844
cal844
  • 9,639 posts
  • Local Club: TFMOC
Posted 24 August 2020 - 01:38 PM
I use resistor type plug leads and NGK BPR6ES plugs, the only combination to totally eradicate interference through the speakers.
I use this setup on standard 998 and 1275 engines, you could also use it on mildly tuned motors too
Keep your old plugs incase you need to paint the engine.
Edited by cal844, 24 August 2020 - 01:41 PM.
#3 MCCS.Eng
MCCS.Eng
  • 20 posts
Posted 24 August 2020 - 04:40 PM
Hi,
NGK plugs always seem good. If your engine is running standard compressions then the BPR6ES plugs are perfect. If you are running higher compression (anything above say 10.2:1) you could look at BPR7ES
#4 psoutzis
psoutzis
  • 278 posts
Posted 25 August 2020 - 07:21 AM
Thank you all. What about HT leads ? are there any specific HT leads for the electronic ignition ?
Edited by psoutzis, 27 August 2020 - 03:31 PM.
#5 psoutzis
psoutzis
  • 278 posts
Posted 27 August 2020 - 03:31 PM
#6 MCCS.Eng
MCCS.Eng
  • 20 posts
Posted 08 September 2020 - 06:06 PM
Most leads these days are double insulated. So long as you don’t use the old school copper cored you will be fine. Should be able to pick them up from any motorfactor :-)
#7 Dusky
Dusky
  • 5,322 posts
Posted 08 September 2020 - 06:30 PM
Ngk 5 is the stock heat range for most mini engines. 6 is already a heat range colder than stock/ cooper & MG metro heat range. Dont make the mistake of going too cold.
