Engine Bay Really Hot
10 replies to this topic
#1 rodandtom
rodandtom
  • 998 posts
Posted 27 August 2020 - 06:45 PM
Hi,
1293, '94 Sprite. Took it for a run the other day. All was good. Ran really well. Temp gauge was ok but when I got home both wings were hot to the touch. Even the headlight glass was hot. In the bay everything was too hot to touch from the rocker cover down.
I'm worried my head gasket is cooked. There was no mayonnaise in the cap but it was low on oil. Although oil pressure was ok and didn't change. When it cooled down I drained the coolant (which was mostly water as I hadn't put the right mix of coolant in. The water was brown but not oily ( to my view). I flushed the system with a house until it ran pretty clear, refilled with the right mix of coolant this time. Topped the oil up a d took her out again. Ran even better. I can't tell if my head gasket is stuffed or not. If it isn't, them why the hell is my engine bay so bloomin hot?
Any ideas?
#2 nicklouse
  • 18,660 posts
Posted 27 August 2020 - 07:04 PM
Does not sound like you have a problem.
but you could do a compression test.
#3 rodandtom
rodandtom
  • 998 posts
Posted 27 August 2020 - 07:27 PM
Good idea.
How do you tell If your water pumpnisnt pumping? I wondered if the coolant wasn't circulating.
#4 Midas Mk1
Midas Mk1
  • 5,786 posts
  • Local Club: S.U.N.M.C
Posted 27 August 2020 - 11:39 PM
After doing something like London to Brighton, the near side wing and wheel is red hot.
I'd get a digital laser thermometer gun off eBay to check, but they do get warm. When a mini engine gets hot they give off a hot smell.
#5 nicklouse
  • 18,660 posts
Posted 28 August 2020 - 12:00 AM
Good idea.
Cold engine. Remove rad cap. Rev engine while watching the water level. It should drop and come back up as the water is pumped.
#6 richmondclassicsnorthwales
  • 942 posts
Posted 28 August 2020 - 02:34 PM
Antifreeze is not only to stop the water freezing, it is also a coolant, so see how you get on now.
#7 johnR
johnR
  • 2,301 posts
Posted 28 August 2020 - 03:50 PM
have you had the fan off recently and installed it the wrong way round?
#8 rodandtom
rodandtom
  • 998 posts
Posted 28 August 2020 - 06:50 PM
Sadly not
#9 Alice Dooper
Alice Dooper
  • 391 posts
  • Local Club: Minis in Northern Ireland
Posted 22 September 2020 - 10:24 AM
If all is ok with the engine, gaskets and cooling system, have you considered wrapping the exhaust manifold??
Anything on the front grill blocking the airflow in?
#10 nicklouse
  • 18,660 posts
Posted 22 September 2020 - 10:56 AM
Don’t wrap the exhaust manifold. It crystallises the steel and they fail. And you just end up moving the heat further along the system so you get a hot floor pan.
#11 MiNiKiN
MiNiKiN
  • 200 posts
Posted 22 September 2020 - 02:59 PM
and it prevents corrosion in the engine's water ways. Good job that is, cause rust prevents efficient heat exchange between metal and water.
