Clutch biting points changing!!
8 replies to this topic
#1 ellensmini
ellensmini
  • 56 posts
Posted 30 October 2006 - 05:30 PM
i wonder if anyone can shed any light, my girlfriends mini clubman would not go into gear today,
after having a look myself and adjusting the clutch up, 4 times out of five the clutch now bites nice and high. one 1/5 it bites really really low.
The car has a brand new clutch in and also and brand new slave cylinder. also i cant see any leaks ( although it is dark :genius: )
any ideas?
thanks
dale
#2 Big_Adam
Big_Adam
  • 7,435 posts
Posted 30 October 2006 - 05:56 PM
i'd try bleeding it again. then adjusting once bleed.
thats the most i can think of.
#3 ellensmini
ellensmini
  • 56 posts
Posted 30 October 2006 - 05:58 PM
nice one, ill give it a go, only thing i haven't change is the master cylinder, could it possible be that, only other thing i have seen is the flexi pipe has a serious kink in it. could this be a possiblity
#4 fikus01
fikus01
  • 1,910 posts
  • Local Club: SMAG - Southend Mini Action Group
Posted 30 October 2006 - 07:00 PM
if the bite point keeps changing it could be a worn pin or arm in the linkage!!
#5 ellensmini
ellensmini
  • 56 posts
Posted 30 October 2006 - 07:06 PM
yeah it completely changes, from top to bottom?
#6 fikus01
fikus01
  • 1,910 posts
Posted 30 October 2006 - 07:08 PM
check the roll pin in the bottom of the clutch cylinder!! bit of a bugger to get to but it could be the pin rotating!! or as the others say could be air in the system
#7 blacktulip
blacktulip
  • 6,224 posts
Posted 30 October 2006 - 07:29 PM
does it rise when u pump it? sorry about the inuendo :P if so then i would say it need re-bleeding too.
#8 ellensmini
ellensmini
  • 56 posts
Posted 30 October 2006 - 08:10 PM
yes mate, seems like first time the clutch only parts slightly, with a couple more pumps the seperation is bigger
#9 blacktulip
blacktulip
  • 6,224 posts
Posted 30 October 2006 - 08:32 PM
have u re-bled it? it should sort it out.
