Squeak From Drivers Side Driveshaft When Rotating
Posted 29 August 2020 - 11:13 AM
Posted 29 August 2020 - 04:03 PM
Posted 28 February 2021 - 09:20 AM
Mine is coming from the inner CV on the gearbox end so tightening the drive flange isn’t likely
to resolve.
Posted 28 February 2021 - 09:43 AM
It's not a pip-squeak is it ?
OK,,,, OK,,,,,, I'll run away and take cover now,,,,,,
Posted 28 February 2021 - 09:57 AM
It’s like this (excuse wind noise and engine)
https://youtu.be/arr2868W4fI
Only materialises when hot oddly, but definitely coming from the inner CV.
I think it may just be the boot, doesn’t sound like metal grinding!
Posted 28 February 2021 - 10:00 AM
Not something like Disc Pads rubbing or similar ?
Posted 28 February 2021 - 10:05 AM
Posted 28 February 2021 - 10:32 AM
Posted 28 February 2021 - 10:39 PM
Definitely no clunking nor sounds like ball bearings were falling apart inside either!
Posted 07 March 2021 - 07:44 PM
Today after a drive the squeak got really loud and could hear it from inside the cabin so got home and jacked up the car and got someone to turn the wheel whilst spraying WD40 silicon spray around the inner pot joints/boots. Suddenly the noise went away! It seemed to be spraying the pot joint end facing the diff case that made it go away (not the end the shaft comes out of if that makes sense?) — I understand spraying is usually a temp fix.. do you think I’ll eventually need new pot joints, or they may have just got a bit squeaky?
Posted 07 March 2021 - 07:59 PM
Even though the boot may not be damaged, water / moisture still gets in. This is one of the pot joints off my 74 clubby. It was as old as the car, boot was intact, supple and no damage.
Posted 07 March 2021 - 09:49 PM
It’s odd how spraying where I did solved the squeak (was the same on both sides of the diff) as there are no ‘free rotating parts’ just a splined rod going into a ‘receiver’
Posted 08 March 2021 - 08:59 AM
Did you remove the inner boot clip off that Sonik?
Posted 08 March 2021 - 10:03 AM
Nope, when i originally removed the drive shafts for the resto i left the gaiter and ball bearing race attached to the shaft but bagged up. The cup was removed.
To the OP, i know in some circumstances if the grease has been missing / damaged gaiter then the bearings will run dry. The pictures below show a really knackered pot joint, one that was on my sons car. As we never drove the car on the rd before it was bought we don't know how much noise this would have made??
The fact you have sprayed WD40 at the entry point to the diff housing makes me think its wont be this but however it might be worth a check.
Posted 19 April 2021 - 02:33 PM
Just to let everyone know in case anyone has the same issue, I got some 3-in-1 Oil with PTFE spray, gave it a good spray up there and so far, touch wood, the noise hasn't come back :)
