Stage One Needle For Maniflow Stage 1 Kit?
11 replies to this topic
#1 noeman
noeman
  • 125 posts
Posted 30 August 2020 - 08:56 PM
I'm going to be fitting my maniflow stage 1 kit to my 998 with hs4 carb.
The stage 1 kit didn't come with a needle. What needle do you think i should use AAU?
Thanks for any help
#2 cal844
cal844
  • 9,648 posts
  • Local Club: TFMOC
Posted 30 August 2020 - 09:44 PM
Use AAU, to get you to a rolling road
#3 Anthony30
Anthony30
  • 1,467 posts
  • Local Club: N/A
Posted 30 August 2020 - 09:55 PM
AAU is best. AAA will be far too rich. That's what I used anyway.
#4 cal844
cal844
  • 9,648 posts
  • Local Club: TFMOC
Posted 30 August 2020 - 10:05 PM
That's the needle that comes with the Minispares Stage 1 kits... It gets me close enough that I don't bother with rolling roads
#5 noeman
noeman
  • 125 posts
Posted 31 August 2020 - 07:22 AM
I thought AAU, but I read on the minispares website it is suitable for their stage 1 kit and RC40 but may not give as good results with other manufacturers kits and exhausts, so i wasn't sure.
I'll be taking it to a rolling road anyway.
Edited by noeman, 31 August 2020 - 07:24 AM.
#6 paul748
paul748
  • Just Joined
  • 80 posts
Posted 31 August 2020 - 08:03 AM
I fitted the supplied AAU when I installed the Minispares kit. I also removed the air filter inlet valve thing and drilled a few 20mm holes in the underside of the air box.
Took it for a rolling road tune and ended up with AAM needle. The car runs great with a lot of mid range torque (for a standard 998 :D ). It easily cruises at 70mph plus.
Every MOT I pop the AAU needle back in and it flies through the emissions tests.
#7 blacktulip
blacktulip
  • 6,224 posts
Posted 31 August 2020 - 08:39 PM
Hope you didn't make the holes on the inside if the element ring? The correct place for the holes is around the wall sides of the box.
#8 noeman
noeman
  • 125 posts
Posted 31 August 2020 - 10:49 PM
Otherwise the air flow isn't actually going through the filter.
#9 Tds76
Tds76
  • 87 posts
Posted 01 September 2020 - 03:46 AM
I'm guessing it was done as per Calver.
https://www.calverst...air-filtration/
and scroll down to pic 2.
#10 paul748
paul748
  • Just Joined
  • 80 posts
Posted 01 September 2020 - 06:48 AM
Yes, just like that :D
#11 maystro
maystro
  • 298 posts
Posted 01 September 2020 - 12:51 PM
Just my two cents worth, I have a 998 with a 12g202 head which has been ported to stage 2/3 level with big valves, double valve springs and a Kent 276 cam and a single Hs4 and found the AAU to be running to lean. I then tried a AAB which seemed a bit rich and finally settled on a AAM which is so sweet now.
I also bought a brand new HS4 to trial all these needles which came with a ABP needle which was very lean which is suppose to be suited to standard 1100 motors.
Go with the AAM needle I reckon. It will still be good if you do a few minor upgrades.
Brad
#12 Anthony30
Anthony30
  • 1,467 posts
  • Local Club: N/A
Posted 04 September 2020 - 10:20 PM
Brad
To be fair, the standard head is very restrictive, so the added air made the mixture too lean. :) I loved my modified 998 engine. so smooth and loved to rev
