Electrical Queries
8 replies to this topic
#1 I hate Brian
I hate Brian
  • 782 posts
Posted 01 September 2020 - 04:58 PM
Hi can someone help- out on the wiring issues, see attached :
Where do the earths go next to the servo
The distributor is from Keith Calver where do these connect to as they are red and black and is it the two white red cables shown and is polarity needed cheers in advance
#2 GraemeC
GraemeC
  • 7,467 posts
Posted 01 September 2020 - 05:03 PM
There is normally a threaded hole on (or near) the triangular strengthening bracket that has a screw in it for those earth cables.
Dizzy should take power from the coil - red to +ve; black to -ve.  However post a picture pf the existing coil connections so we can check it isn't a ballast supplied type
It is not the white/red cables - I can't work out what they'd be for in that location, unless it is the auto inhibitor switch.
Edited by GraemeC, 01 September 2020 - 05:07 PM.
#3 cal844
cal844
  • 9,713 posts
  • Local Club: TFMOC
Posted 01 September 2020 - 05:12 PM
Bang on Graeme and a good guess on the white red wires, they are indeed for the inhibitor switch
These should just be joined together
Edited by cal844, 01 September 2020 - 05:12 PM.
#4 johnR
johnR
  • 2,318 posts
White/red are often something to do with the starter - don't know if that's the case here?
Ahh, not in this case!
Edited by johnR, 01 September 2020 - 05:13 PM.
#5 I hate Brian
I hate Brian
  • 782 posts
Posted 01 September 2020 - 05:23 PM
Hi I've converted from an SPI  to carb so original distributor was an SPI, new loom from Autosparks for a carb mini, (what's the inhibitor switch for ) are the white black cables to the coil ? coil is Lucas sport coil as from Keith Calver
Edited by I hate Brian, 01 September 2020 - 05:25 PM.
#6 cal844
cal844
  • 9,713 posts
  • Local Club: TFMOC
Posted 01 September 2020 - 05:26 PM
Inhibitor switch for the automatic transmission cars, it's basically a switch so the car doesn't start in drive or reverse
#7 I hate Brian
I hate Brian
  • 782 posts
Posted 01 September 2020 - 05:28 PM
Hi so are the white black wires the feed for the coil ?
#8 GraemeC
GraemeC
  • 7,467 posts
Posted 01 September 2020 - 06:09 PM
The white/black should be on the negative side of the coil.
The positive side should have a white cable to it.
You might need to join the white/red together if the car won’t turn over on the key.
#9 I hate Brian
I hate Brian
  • 782 posts
Posted 01 September 2020 - 06:33 PM
Cheers Graeme, Cal and John R
