1990 1275 cooper, standard suspension, almost 100,000 miles
Hi
After my mini sat for 13 years, I recently put it back on the road and have probably done around 1000 miles.
After those miles, some things have started to un-seize. One of the things is the front bottom passenger's side ball joint. I jacked up the car last night and there is quite a lot of play in the joint.
Obviously the best thing is to replace it ASAP, however I don't have a garage atm, and will be putting the mini away for the winter in a month or so- so would rather wait until then. My question is: will it cause damage elsewhere, driving around with a worn ball joint? If it is just wearing the ball joint out (which will be replaced), then I am not too fussed. However if there are knock on effects (pun) then I don't want to damage other components.
I have tried to pump more grease in, however it was not going into the joint. I'll order new nipples in the meantime, and try and pack the joint with grease.
thanks in advance
