Dashboard Aluminium...
1 reply to this topic
#1 LionelMonza
LionelMonza
  • 68 posts
Posted 07 September 2020 - 10:09 AM
Hello,
on my MPI of 2000 the dashboard plugged aluminium is damaged, so I ordered an aluminium dashboard from minispares, but it's not plugged, so it's nice but when I present the meter block on the dashboard the meters don't stick, the rods or tubes where the flashing light and air bag are are blocked.
You have already done this installation? If so, there are parts to buy or modifications to make?
it is necessary to cut the tubes here is the photo
thank you for your advice.
regards
#2 1314cc
1314cc
  • 303 posts
  • Local Club: tumbleweedminisbristol
Posted 07 September 2020 - 03:49 PM
usual thing is to cut the tubes then screw the triple clocks to the binnacle. Any holes missing for additional lights can be drilled .
When you refit first locate the bracket on the right then connect speedo, rev counter etc. You can then push the pinnacle in ,
stick your arm through the pocket and tighten the nut on the left side. You need to remove the original bracket that held the clocks in place too.
