If you're dialing out differences I assumed that means that the 4 lower and upper pivot pins are not parallel to each other in some configuration or other, which sounds like a bad thing?
Err, could be, I have no idea?
Do you have height adjustable suspension ( Hi-Lo's)? Or maybe the rubber doughnuts are requiring replacing? Or even if the tyre pressures are different? As with my Clubman if there's even a small difference in height from one side to the other then this will have an effect on camber as a Mini isn't very wide!
Yes, everything is going to be adjustable. The situation with the camber difference was only to illustrate why I want everything to be adjustable, it used to be the situation on one of my previous Mini's. I suspect this one will be OK.
What do you guys think about this?
I've used similar arms a few times, only I got them from another supplier. They have been around a very long time. As the Threads are large in diameter, that amount of movement in the threads is normal and what one would expect. They are not intended to be precision threads like you'd find on a Micrometer. From memory these are 3/4" in dia. Next time you have the opportunity, try a 3/4 Nut on a Bolt and feel how they fit.
Bottom line is, they are fine and in fact a stronger design than many others out there.
OK, that sounds plausible and is reassuring. I recently saw a Might Mini that actually had these lower arms, so maybe it's not really an issue...
Believe it or not but std threads have an engagement ie touching metal to metal once torqued up of only 30%. That space is to allow these to be done up easily and as mentioned above clearly this can be tighter in closer toleranced items. Trouble with this space is it allows water in and therefore corrosion and the pain to remove / adjust in the future. Use of Loctite 290 in this situation would be advised. 290 is applied after you’ve adjusted and locked down and it wickes in to the thread. Stopping it vibrating loose and also more importantly fills the gap so can’t corrode as no gap. Then just use hand tools when need to adjust to break the Loctite bond.
Good idea about the Loctite, will keep that in mind. Would you put the Loctite only on the locknuts or on/in the central tube as well?
