Steering Rack U Bolts
8 replies to this topic
#1 1314cc
1314cc
  • 303 posts
  • Local Club: tumbleweedminisbristol
Posted 12 September 2020 - 09:35 AM
The friction strips on the steering rack u bolts looks knackered.
Is it possible to remove the u bolts without lowering the subframe?
#2 cal844
cal844
  • 9,645 posts
  • Local Club: TFMOC
Posted 12 September 2020 - 10:06 AM
No you need to lower the subframe, if the nuts are tight it will be OK, I have run minis for 10 years and don't fit new friction strips.
#3 sonikk4
sonikk4
    Twisted Paint Polisher!!!
  • 16,080 posts
  • Name: Neil
Posted 12 September 2020 - 10:49 AM
Callum all because you have run them like that for ten years does not make it right. OP they are there for a reason.
But even with a engine free bay it’s nearly impossible to change them. So dropping the subbie by a few inches is the way fwd.
#4 cal844
cal844
  • 9,645 posts
  • Local Club: TFMOC
Posted 12 September 2020 - 12:40 PM
Yes I understand they are there for a reason. Just pointing out that I don't use them if they ain't fitted, it hasn't caused any issues for me...
They are cheap enough to buy or make from a vinyl.
The subframe will need lowered by a few inches for clearance
Edited by cal844, 12 September 2020 - 12:40 PM.
#5 1314cc
1314cc
  • 303 posts
Posted 12 September 2020 - 01:03 PM
ok thanks, I guessed that would be the case.
I seem have a little bit of movement when say looking down by manifold , whilst turning the steering wheel
#6 cal844
cal844
  • 9,645 posts
  • Local Club: TFMOC
Posted 12 September 2020 - 03:02 PM
Try tightening the 4 U bolt nuts slightly, if that works, personally I'd leave it until the rack needs changed BUT check the nuts are tight once a month
#7 sonscar
sonscar
  • 3,047 posts
Posted 12 September 2020 - 05:25 PM
I refitted them to mine as they were originally there but could not think of a reason for them,not so obvious to me but there must be a technical need for them,but what?Steve..
#8 sonikk4
sonikk4
  • 16,080 posts
  • Name: Neil
Posted 12 September 2020 - 05:57 PM
So the casing is made from Aluminium. You are using a steel clamp and clamping Aluminium against a steel seat. With the friction strip it will clamp at a lower torque to prevent damaging the body of the rack.
Called an anti friction strip this plain looking (plastic) piece of strip is used on all mini steering racks between the U bolt and the rack probably because the U bolt is hard steel and the rack is softer rough cast alloy.
#9 sonscar
sonscar
  • 3,047 posts
Posted 12 September 2020 - 09:47 PM
Probably?,Steve..
