Cv Fitting Tool (Tool21) Dimensions
Best Answer andyapanel , 15 September 2020 - 11:45 AM
The fan spacer will do the trick.
Go to the full post
5 replies to this topic
#1 fokko
fokko
  • 167 posts
  • Local Club: Mini Seven Club Nederland
Posted 15 September 2020 - 11:13 AM
Can somebody post the dimensions of the CV Fitting Tool from Minispares? It hasn't been in stock for a while and I'm going to source something like this in my local hardware shop. I'm talking about this one: http://minispares.co...OOL21.aspx?0108
#2 GraemeC
GraemeC
  • 7,446 posts
Posted 15 September 2020 - 11:22 AM
The dimensions are in (one of) the Haynes manuals - can't remember them off hand but I'm sure they've been posted before.
I doubt you'll find a similar sized washer off the shelf, but one could easily be made by an engineering shop.
Essentially he inner diameter needs to fit over the CV, the outer diameter needs to be sufficient that it acts on the drive flange and the thickness needs to be enough that it doesn't deform with the high torque applied to the nut.
#3 Spider
  • 15,201 posts
Posted 15 September 2020 - 11:40 AM
The one listed for M22 will do the job
https://www.fastener...teel-f436m.html
Personally, I've never done the job with these.
#4 andyapanel
andyapanel
  • 627 posts
Posted 15 September 2020 - 11:45 AM   Best Answer
#5 fokko
fokko
  • 167 posts
Posted 16 September 2020 - 11:40 AM
Thanks to the other people who answered, but I must say I'm impressed! Indeed, the fan spacer fits, so thanks a lot for this great advice!
Attached File  20200916_110323761_iOS.jpg   60.95K   0 downloads
#6 johnR
johnR
  • 2,303 posts
Posted 16 September 2020 - 05:42 PM
I had one made recently - I think it was an inch hole in a 2" x 5mm thick disc.
