Spin On Filter Conversion
13 replies to this topic
#1 1963MKI
1963MKI
  • 163 posts
Posted 16 September 2020 - 12:36 PM
Is there any conversion kit for mk1 block to spin on filters?
#2 GraemeC
GraemeC
  • 7,438 posts
Posted 16 September 2020 - 12:45 PM
Just change the filter head?
I think I may have one of the older style ones that looks more like the cartridge type head somewhere (uses the long studs)
Edited by GraemeC, 16 September 2020 - 12:47 PM.
#3 1963MKI
1963MKI
  • 163 posts
Posted 16 September 2020 - 03:35 PM
yes but I have the very old type filter housing with the different style mating to block ? as number 14 in the picture.
https://www.google.c...QAAAAAdAAAAABAJ
Or are they interchangable ?
#4 GraemeC
GraemeC
  • 7,438 posts
Posted 16 September 2020 - 03:46 PM
They are interchangeable - just different ones use different gaskets.
I have on that looks like item 15 (rather than the new style one that MiniSpares sell) which I'm sure uses the same item 14 gasket (rather than the item 17 gasket)
#5 floormanager
floormanager
  • 698 posts
  • Local Club: Mini Club Sussex
Posted 16 September 2020 - 05:59 PM
or one of these
https://www.flexolit...FILTER_ADAPTORS
#6 nicklouse
  • 18,605 posts
Posted 16 September 2020 - 07:56 PM
44 quid! When you can get a new oil filter head for less than half that.
#7 floormanager
floormanager
  • 698 posts
Posted 16 September 2020 - 08:00 PM
Yes expensive but there must be a market there.
#8 timmy850
timmy850
  • 3,342 posts
  • Local Club: MITG
Posted 16 September 2020 - 09:36 PM
Here is a full kit using the TAM2097 head, new studs and gasket (shows all the part numbers too). You can get all the same parts from minispares & fits all minis
https://minisport.co...-conversion-kit
#9 whistler
whistler
  • 1,797 posts
Posted 17 September 2020 - 08:13 AM
There might not be enough room for that as it drops the filter close to the subframe horizontal. I know that the Metro Van sandwich oil cooler adaptor can't be itted for that reason......it hits the subframe.
#10 Ethel
  • 25,969 posts
Posted 17 September 2020 - 08:43 AM
Seem to recall there was a shorter filter that got round that.
Though this one claims to be for MPIs
https://www.minispor...cooler-kit.html
#11 Spider
  • 14,909 posts
Posted 17 September 2020 - 08:52 AM
There's also a 'Joggle Block' (for want of a term) that was fitted to the Sprites and Midgets (or some of them ?). I have one in the workshop presently, if I remember, I'll snap off a photo.
Basically it lifts the head by about 1 to 1-1/2".
#12 GraemeC
GraemeC
  • 7,438 posts
Posted 17 September 2020 - 09:01 AM
As Nick's says - all that's a lot of hassle (and cost) when you can change the filter head for £15!!
(I think you've all headed down an alley of solving a different problem to what the OP asked)
#13 phillrulz
phillrulz
  • 617 posts
Posted 17 September 2020 - 02:39 PM
excluding vat and carriage....
#14 1963MKI
1963MKI
  • 163 posts
Posted 18 September 2020 - 09:22 AM
youre correct, its quite a long body on the old style filter.
Yes, the only reason I was considering switching to a spin on was to eliminate one point of oil leaks. The old style you get a slight leak from where the body meets the block, a leak where the bowl meets the body, and a leak where the bolt goes through the bowl. While if you switch to spin on, you eliminate one point of possible oil leaks (and its a little easier to change the filter)
