Hi all,
First time posting here. I'm currently restoring a 1275GT with a Weber 40DCOE and I cannot get it started for love nor money. The pre A+ 1275cc (bored out to 1340cc) Engine was rebuilt years ago (so assumed good compression) and hasn't been ran since so all internals are brand new. Brand new battery (kept fully charged), new spark plugs, new electric fuel pump. After a few pumps of the throttle pedal to introduce some fuel in to the cylinder, it turns over fast and sounds like it's trying to start, but it never manages to start. After removing the spark plugs after cranking they smell like fuel. Even squirting easy start in to the intake while cranking has no effect. So far I have tried:
- Checking each spark plug for spark
- Checking battery voltage
- Checking that engine is grounded properly
- Checking adjustment on idle mixture screw.
- Checked and adjusted valve clearance
Can anyone recommend anything else to try before I hand it over to a garage?
TIA
Tom
