1991 Jdm 998 Build + Auto To Manual
3 replies to this topic
#1 Jorgenson Motor Co
Jorgenson Motor Co
    Starting My Mini Up
  • Just Joined
  • 4 posts
Posted 18 September 2020 - 03:43 PM
Can't wait to post all my pictures here and show the progress as I keep working on this mini. I've had it about a year or so and have been loving the car. Recently the auto box is going out so I've been collecting everything to swap to manual. This was the plan all along anyways, but with the transmission dying, I'm now more motivated.
The intent of this car is to be a decently comfortable car to take to work and on trips out of town while being fun to drive. No intentions of it being faster than pretty much anything else on the road, but enough power to keep up in modern traffic.
Suspension:
Coil spring conversion
Adjustable heim joint front lower arms
Gaz adjustable shocks
Minispares rear swaybar
Solid front subframe mounts
Poly rear subframe mounts
Wheels/Tires:
12x4.5 stock wheels w/ Nankang SV-3 winter tires
10x5 Minitor  w/ Yokohama A032R's
Engine:
MED lightweight balanced pre-verto flywheel/clutch assembly
MED-Piper RS cam w/lifters
CAM4810 head mildly ported, skimmed, and valves lapped
Lightweight duplex timing chain
Minispares torquemaster intake manifold
Maniflow header and custom 2" exhaust
2.78 F/D
Edited by Jorgenson Motor Co, 18 September 2020 - 05:09 PM.
#2 nicklouse
  • 18,697 posts
Posted 18 September 2020 - 04:09 PM
Shame you fitted the worse suspension you could.
#3 Jorgenson Motor Co
Jorgenson Motor Co
    Starting My Mini Up
  • Just Joined
  • 4 posts
Posted 18 September 2020 - 05:11 PM
I've definitely gotten that from alot of people. It does make for a nice ride around town.
#4 Jorgenson Motor Co
Jorgenson Motor Co
    Starting My Mini Up
  • Just Joined
  • 4 posts
Posted 01 October 2020 - 03:42 PM
Getting more work done on the motor. Paint is finished and I got the cam in and timed. With the normal key, it timed in at 103. Luckily I had a 2 degree offset key so I installed that and checked again that it moved to 105. Figured that should be good, especially with a new chain that may stretch slightly.
Edited by Jorgenson Motor Co, 01 October 2020 - 03:42 PM.
