Washer/wiper Stalk Wiring
6 replies to this topic
#1 masslaw
masslaw
  • 109 posts
  • Local Club: Victoria Mini Owners Club
Posted 28 September 2020 - 01:23 AM
I have undone this black ground wire at the wiper/washer stalk.  It is in the most advanced position in the picture but I cannot figure out how to reattach it.  There is no obvious connection point.  I've been told it's the ground for the washer motor.  Anybody?
#2 Maccmike8
Maccmike8
  • 1,101 posts
Posted 28 September 2020 - 08:10 AM
Take the wheel off then take the indicator assembly off. Once off Im sure youll easily find the wires home.
#3 sonscar
sonscar
  • 3,064 posts
Posted 28 September 2020 - 09:45 AM
Only a dim memory but is it kind of trapped under the stalk sleeve?Wire looks braided for flexibility not terminations,Good hunting.Steve..
#4 Ethel
  • 26,115 posts
Posted 29 September 2020 - 09:07 AM
The metal arm is used as a conductor for the push switches on the end of the stalks.
#5 oohaargh
oohaargh
  • 28 posts
Posted 24 January 2021 - 10:43 AM
Did you get to the bottom of this? I've got exactly the same problem.
There's two prongs on the end of the stalk which get connected when you push in the washer button on end, so it would make sense if the green/black wire goes all the way up inside and connects to one prong, and the other is connected to the metal stalk itself with the black wire just connected at the bottom. That said, no idea how exactly it's supposed to be connected, is it just pushed up into the same hole as the green/black wire?
#6 oohaargh
oohaargh
  • 28 posts
Posted 24 January 2021 - 09:36 PM
Sorted this in the end - you can pull the stalk out of the plastic housing, put the black wire into the hole where the stalk fits then push the stalk back in over the top of it to trap the wire against the metal connector on the base of the stalk
#7 masslaw
masslaw
  • 109 posts
Posted 01 February 2021 - 05:36 AM
Found this
