Lined everything up, then got the shims for the crankshaft.
Then found the engine wouldn’t turn over as the back of the vernier wheel is hitting the triangle bolt heads.
Can I lose the washers and run with just locktite?
Should I run without washers to give more clearance or find slimmer washers?
I rang minispares but not really got a clue and it won’t be them who have to take the engine apart to get at it if it comes undone, so over to you for advice please!
Edited by Minigman, 30 September 2020 - 03:05 PM.
