Con Rod Bearings
14 replies to this topic
#1 cristiano1968
cristiano1968
  • 444 posts
Posted 30 September 2020 - 07:54 PM
Hi in the middle of a rebuild.
Getting ready for the machine shop.
My question is what's the right orientation of the Conrad bearings.
I made sure to mark each Conrad after removal so not to mix up.
Should the notches on each bearing line up or should they be opposite each other.
I will be putting new pistons in .
I think the notches should be opposite each other .is it correct in the photo?
Can anyone conferm?
#2 imack
imack
  • 2,372 posts
Posted 30 September 2020 - 08:17 PM
Notches go together
#3 cristiano1968
cristiano1968
  • 444 posts
Posted 30 September 2020 - 08:19 PM
Ok thanks
#4 cristiano1968
cristiano1968
  • 444 posts
Posted 30 September 2020 - 09:58 PM
It's a 998cc a +
They don't seem to match up.
Whichever way I try.
I didn't mix them up when I removed them from the crank.
I punched marked each one .
Unless I'm going mad?
I remember correctly numbering each conrods etc
#5 cristiano1968
cristiano1968
  • 444 posts
Posted 30 September 2020 - 10:10 PM
Just been looking through mini books
These are for older car minis mine are press fit pistons.
#6 cristiano1968
cristiano1968
  • 444 posts
Posted 30 September 2020 - 10:11 PM
The notches or tangs are on the same side but opposite each other
#7 cristiano1968
cristiano1968
  • 444 posts
Posted 30 September 2020 - 10:36 PM
Found an old minimagazine tech
#8 cristiano1968
cristiano1968
  • 444 posts
Posted 30 September 2020 - 10:40 PM
On my crankshaft main bearings
The notches /lines/grooves match up.
#9 sonscar
sonscar
  • 3,198 posts
Posted 01 October 2020 - 06:57 AM
I thought The rods and caps have notches for the shells to fit in.A long time since I saw mine but it "should" be obvious.Steve..
#10 gazza82
gazza82
  • 3,086 posts
  • Local Club: TMF+
Posted 01 October 2020 - 07:48 AM
They do.
#11 gazza82
gazza82
  • 3,086 posts
  • Local Club: TMF+
Posted 01 October 2020 - 07:49 AM
Notches go together
Did you actually mean notches on same side? They don't go together or line-up ... the images in the manuals ARE CORRECT!
#12 GraemeC
GraemeC
  • 7,467 posts
Posted 01 October 2020 - 08:29 AM
Your photo is correct.
The edges of the bearings with the notches go together.
#13 cristiano1968
cristiano1968
  • 444 posts
Posted 01 October 2020 - 08:47 AM
Ok thanks
#14 imack
imack
  • 2,372 posts
Posted 01 October 2020 - 09:06 AM
Notches go together
Yeah, on the same side
#15 cristiano1968
cristiano1968
  • 444 posts
Posted 01 October 2020 - 10:29 AM
Yea that's what I thought that the notches have to line up together.
Now I know they don't ☺
I thought I'd messed up the caps
But I didn't
Thank god
