Oil Pressure Switch
2 replies to this topic
#1 AlasdairM
AlasdairM
  • 240 posts
Posted 01 October 2020 - 08:11 AM
Hi folks
1990, 1275 cooper
Attached is a pic of my oil pressure switch. I’ve only just realised that the indicator light on my dash is not working (after driving the car all summer!). I guess there should be a low pressure light which comes on, next to the ignition light on the dash?
To test if it’s the sensor or the bulb in the dash, if I unplug the sensor, the light still doesn’t come on. Should I try shorting the wire to an Earth point on the car?
If I need a new switch, will I just buy a standard one from minispares? I can’t seem to find one that looks like my current one.
Thanks for the help.
Alasdair
#2 KTS
KTS
  • 2,490 posts
Posted 01 October 2020 - 08:26 AM
earthing the sensor wire should cause the bulb to light
edit:  ..with the ignition on !
Edited by KTS, 01 October 2020 - 08:30 AM.
#3 AlasdairM
AlasdairM
  • 240 posts
Posted 01 October 2020 - 12:48 PM
thanks. Earthing the sensor did indeed turn the light on- so I've ordered a new switch.
