Inlet Manifold : Brake Servo To Banjo Bolt
6 replies to this topic
#1 Elwyn
Elwyn
  • Just Joined
  • 365 posts
Posted 05 October 2020 - 08:27 AM
Hello
1993 L reg Cooper SPI
I have recently replaced the water and air temp sensors as well as the lambda sensor
Inlet manifold taken off and put back to do so
My issue is with the brake servo banjo bolt
It's leaking brake fluid at that point
At the inlet manifold end
From the hose connecting to the banjo bolt
At the banjo bolt
I have also recently had the front wheels off, and taken off / refurbished / replaced almost everything visible (callipers, cv joint, gaiters, swivel hub, tie rods, flexy brake hoses, track rod ends etc)
There is still brake fluid in the system, but it's not been bled yet
I am heading to the back wheels next to replace shoes, springs etc (and the radius arm, with reamer etc)
So, aside from the context, any idea why there's a leak at the banjo bolt?
The hose is on tight
There's the angular "thing" that sits at 90 degrees to strike the manifiold to help secure / tighten things up without them spinning....does that need to be in a particular position?
Thanks in advance
Edited by Elwyn, 05 October 2020 - 08:28 AM.
#2 brivinci
brivinci
  • 1,192 posts
Posted 05 October 2020 - 04:27 PM
Sorry, are you saying that there is brake fluid leaking out of the very large banjo bolt on the intake manifold?? That is WAY wrong. That pipe is there to provide the brake server with vacuum pressure and should not have any fluid at all in it.
You should remove the brake master and server and have a good look around. I have no idea how fluid could be getting in there unless the master is leaking and filling up the server unit.
#3 Elwyn
Elwyn
  • Just Joined
  • 365 posts
Posted 05 October 2020 - 04:38 PM
It looks like that yes, but since I spotted it, it hasn't stopped raining, so I'm not 100% sure
I don't have a garage
I work on the drive
Very weather (and sunlight) dependant
Frustrating at this time of year
It definitely looks that way
I can't see where else the brake fluid is coming from
Nothing else has been touched
#4 sonscar
sonscar
  • 3,027 posts
Posted 06 October 2020 - 08:11 AM
For fluid to come out of there the servo would need to have filled up,this would mean you have topped up the brake fluid 50? times.It is unlikely to be brake fluid unless you had it hanging down whilst connected to the servo.Steve..
#5 Elwyn
Elwyn
  • Just Joined
  • 365 posts
Posted 06 October 2020 - 08:19 AM
Still waiting for the rain to stop
Noah's been busy
I'll try to work out what's coming from where, but ruling things out is helping
I did top up the brake fluid but only to refill the master cylinder reservoir in readiness for a brake bleed, then immediately saw the leak and stopped
#6 panky
panky
  • 1,792 posts
Posted 06 October 2020 - 12:51 PM
Yep the brake master cylinder seals have gone. I only found out on mine when the pedal went to the floor O_O  The reservoir was empty and the vac line was full of fluid, cue new master cylinder.
#7 Elwyn
Elwyn
  • Just Joined
  • 365 posts
Posted 06 October 2020 - 05:59 PM
I've already ordered a new one from Mini Spares.
