Thermostat Housing Bolt Sheared Off
Best Answer Elwyn , 12 October 2020 - 08:57 AM
Update
Namrick recoil kit arrived
Drilled, tapped, screwed coil in, removed tab, done
5 minutes
Original bolt fits perfectly
Wonderful
Thank you, thank you, thank you
Go to the full post
3 replies to this topic
#1 Elwyn
Elwyn
  • Just Joined
  • 365 posts
Posted 05 October 2020 - 04:34 PM
Hello
1993 L reg Cooper SPI
Thermostat housing with the sandwich plate
3 bolts securing it all
1 bolt has sheared off in the block
I tried to get it out using a left-handed thread bolt removal tool, but failed miserably
I've now mostly drilled the bolt out
I have lost a few drill bits in the process
I have a tap set
Any advice regarding tap size, the need for a different bolt or even a different approach completely?
Is it a stupid idea to consider epoxy / GB weld securing a stud into the hole instead of trying to a cut a new thread?
And holding it down onto the stud with a nut & washer, with the two others still as the bolts as they should be?
Edited by Elwyn, 05 October 2020 - 04:36 PM.
#2 mab01uk
mab01uk
  • 12,486 posts
Posted 05 October 2020 - 09:42 PM
A Heli-Coil kit is usually advised to do the job properly, see Cooperman's post in this thread link below:-
http://www.theminifo...t-housing-bolt/
Namrick Recoil Kits:-
https://www.namrick...._122.html#a4418
Edited by mab01uk, 05 October 2020 - 09:43 PM.
#3 Elwyn
Elwyn
  • Just Joined
  • 365 posts
Posted 06 October 2020 - 08:17 AM
Namrick recoil kit ordered
Aren't mini's fun?!
#4 Elwyn
Elwyn
  • Just Joined
  • 365 posts
Posted 12 October 2020 - 08:57 AM   Best Answer
Update
5 minutes
Wonderful
