Rear Wheel Bearing Timken Part Number Mpi
5 replies to this topic
#1 Rusty Nut
Rusty Nut
  • 21 posts
Posted 08 October 2020 - 08:05 AM
In the complete absence of any stock of Timken rear wheel bearings from all UK and French mini parts stockists, does any one know the Timken part number for the rear bearing?
I have this from a bearing specialist in France -
LM67049A/LM67014-TIMKEN PART NUMBER which is for the fronts looking at  Moke Spider's photos. €32
but Ive just stuck my original rear Timkens back in with grease all over them without taking the part number off them which I agree was thoughtless of me.
I also see
LM67045/LM67014-with the same dimensions but double the price - not sure why
and
LM67048/LM67014-TIMKEN same dimensions and €32 a set.
These all have dimensions of
Diamètre intérieur : 31,75 mm
Diamètre extérieur : 61,99 mm
Width totale : 15,88 mm
The kit does include seal but not  the O ring. Can I find these separately? I didn't see this O ring when I pulled the old (original 1999) bearings off.
#2 Spider
  • 15,021 posts
Posted 08 October 2020 - 08:29 AM
The Bearings are Timken 07087X, Assembly 49644, however, this is an old number when they had a separate spacer, the 'newer' version that has the inbuilt spacers I think may have a different number, but a Bearing distributor should be able to sort it.
The O ring - from memory - is 13/16" OD and 1/16" in section.  If you can't find one, I wouldn't loose any sleep over not fitting one back on.
#3 KTS
KTS
  • 2,452 posts
Posted 08 October 2020 - 08:34 AM
there's more than one recent thread on the forum advising where you can get hold of them
John@Guessworks was able to supply me a full set of timken bearings a short while back
http://www.guess-wor...bottletopracing
Edited by KTS, 08 October 2020 - 09:09 AM.
#4 Spider
  • 15,021 posts
Posted 08 October 2020 - 08:41 AM
I just had a browse in the UK and I see Somerfords look like they have them;-
http://www.somerford...roducts_id=3300
I think to CC Minis (on the forum) also usually stocks them.
#5 Rusty Nut
Rusty Nut
  • 21 posts
Posted 08 October 2020 - 10:05 AM
OK great thanks - John has some!
#6 cian
cian
  • 869 posts
  • Local Club: Minis In Northern Ireland
Posted 08 October 2020 - 12:26 PM
I know your sorted but I have nos rear bearings £30 per side
Cc minis
Edited by cian, 08 October 2020 - 12:26 PM.
