Spi Intake Air Temperature Sensor Connection
6 replies to this topic
#1 psycho mini driver
psycho mini driver
    1 Gold Star
  • 218 posts
Posted 11 October 2020 - 05:16 PM
After 8 year off the road I am in the process of getting the SPI up and running.
Today whilst tinkering replacing all the vacuum pipes, i found the intake air temp sensor was hanging on by a single wire.
The connector wire needs re-soldering, but it would be good to see how it should look, im guessing this is not how they came out of the factory and just re-soldering the wire looks like it might not be too strong and could go again in the future.
https://imgur.com/gallery/ccYP4Kt
#2 tmsmini
tmsmini
  • 728 posts
  • Local Club: MOASF
Posted 12 October 2020 - 02:37 PM
I would replace the plug or at least the pins with the correct version.
You might not find a complete green plug, but parts should be available from Polevolt.
#3 hunterg30
hunterg30
  • 349 posts
Posted 12 October 2020 - 05:02 PM
If the colour does not bother you, go to the scrap yard and cut a black one off a fuel injector fitted to most cars or search on eBay for EV 1 plug green
#4 psycho mini driver
psycho mini driver
    1 Gold Star
  • 218 posts
Posted 12 October 2020 - 06:29 PM
Thats a great help. Thanks to both of you! Now I know what I am looking for a where to look. Colour not important, just as long as the engine is running as good as possible.
Do you know if it matters which way round the wires go? I will stick with the way round they are, and just assume this is correct....
#5 Wazzah
Wazzah
  • 142 posts
Posted 12 October 2020 - 09:07 PM
They are called bosch junior plugs.
Readily available and come with new pins and a rubber boot.
They have 2 crimp tabs and the right crimping tool makes this job a breeze.
Make sure the back tabs bite into the wires insulation.
This helps keep them secure and long lasting.
#6 tmsmini
tmsmini
  • 728 posts
  • Local Club: MOASF
Posted 12 October 2020 - 11:43 PM
Awhile back I put some information in this post:
http://www.theminifo...or-information/
If you click on the link it takes you to a google sheet that has info on the connectors. At the far right is a link to a pin diagram for the wires.
The color code diagram is in the pinned thread for the electrical diagrams.
I was hoping someone would check my work, but I am pretty sure the information is valid.
I could not find the chart easily, but this should do as well:
http://www.tmsmini.c..._Codes_1996.pdf
Colors are pretty much standard BMC/Rover
Edited by tmsmini, 12 October 2020 - 11:54 PM.
#7 psycho mini driver
psycho mini driver
    1 Gold Star
  • 218 posts
Posted 14 October 2020 - 06:55 PM
Thats great. Have managed to source and order one from Ebay with crimp tabs and a rubber boot (which is missing at the moment!)
Great sheet tmsmini! Very nice ?
