1275 A+ 9 Head Studs Torque
4 replies to this topic
#1 lanvid
lanvid
    Just On Tickover
  • Just Joined
  • 6 posts
Posted 13 October 2020 - 06:22 AM
Hi
I used "search" but more i read less i understand. I am changing the head gasket (payen 450) on my 1275 A+ from an rover cooper 1991.
Can you please let me know if the 9 original studs have to be torquened down?if yes how much Nm? Or only tightened by hand, like i read in some posts?
Thank you very much
Edited by lanvid, 13 October 2020 - 06:22 AM.
#2 steeley
steeley
  • Just Joined
  • 623 posts
Posted 13 October 2020 - 06:27 AM
Should be torqued down, check Haynes manual for sequence
Originally posted by cooperman, this what I have always done too
Torque up on initial fitting using the correct sequence to 30 lb.ft, then 40 lb.ft. then finally 50 lb.ft. Set valve clearances accurately using 'rule-of-nine'.
Run engine through a few heat cycles, or drive for around 100 to 200 miles, then loosen each nut in turn by 1/2 a turn and re-torque to 50 lb.ft. Just do one nut at a time, but still in the correct sequence.
Finally re-set valve clearances again, check coolant level and 'jobsagoodun'.
Edited by steeley, 13 October 2020 - 06:31 AM.
#3 lanvid
lanvid
    Just On Tickover
  • Just Joined
  • 6 posts
Posted 13 October 2020 - 06:42 AM
steeley thank you, these is the procedure for torquening the head bolts. my question was for the studs only. before putting back the head
#4 Spider
  • 15,223 posts
Posted 13 October 2020 - 07:29 AM
The normal procedure is hand tight, however, I like to nip them a small bit so that down the track if the head has to come off and the top threads are a bit worse for wear, the stud stays put when undoing the Nut.
#5 Cooperman
  • 23,357 posts
Posted 13 October 2020 - 09:28 AM
That is exactly what I do, using two nuts on the stud. I don't use a specific torque, just 'nip' then up a bit so that they are firm, but not too tight. It seems to work well.
