Can I Remove The Wing Mirror Glass?
7 replies to this topic
#1 noeman
noeman
  • 125 posts
Posted 13 October 2020 - 09:13 PM
As said, can the glass be removed from the wing mirror?
I already have the mirrors off the car,  but I wish to spray the back of them and it would be easier if the glass wasn't there.
I have noticed a small hole at the bottom,  I didn't know if it was just a case of putting something in there and prising them off.  I thought I'd ask 1st as I didn't want to brake them.
Thanks for any help
#2 nicklouse
  • 18,682 posts
Posted 13 October 2020 - 09:24 PM
No idea the Mini never had wing Morris as standard from the UK factory. So it depends what mirrors you have.
#3 noeman
noeman
  • 125 posts
Posted 13 October 2020 - 09:53 PM
Sorry I meant door mirrors, I naturally say wing mirrors.
https://www.minispar...|Back to search
this type
#4 Ethel
  • 26,057 posts
Posted 14 October 2020 - 01:09 AM
Possibly,
Replacement glasses were available, but they were glued together so needed careful prying apart with a stanley knife. New glasses came with new plastic retainers, there's some risk if you're wanting to reuse those bits.
#5 kit352
kit352
  • 244 posts
Posted 14 October 2020 - 06:37 AM
Its near impossible to get them apart sadly. I have ruined a few sets already trying to figure out a way. They always crack or split at some point.
#6 sid trunley
sid trunley
  • Validating
  • 23 posts
Posted 14 October 2020 - 12:07 PM
ive got stainless steal ones they are sprig loaded you push the glass and gently go round the edges with a terminal screw driver and they come out not easy    sid
#7 Johnmar
Johnmar
  • Just Joined
  • 176 posts
Posted 14 October 2020 - 12:46 PM
Maybe not the info you need, but I have the standard rover mirrors,
The consist of a base ( that secures to the door and that attaches to the mirror housing with a pivot-bolt)
The mirror housing,
Glass and a plasic bezel.
When I wanted to paint the mirror housing tahiti blue (leaving the base and bezel black like the cooper mirrors are painted white with black bezels and base), I inbolted the housing from the base and pryed the bezel of with a small screwdriver. Covered the glass with painters tape and sprayed the housings (plastic primer followed by a rattle can in the right colour). Afterwards I just pushed the bezel back in its place. Might that I used a drop of glue for security in the bezel edge.
Johnmar
#8 Red Riley
Red Riley
  • 161 posts
  • Local Club: British Car Club of Charleston
Posted 14 October 2020 - 03:52 PM
As Sid says, some of them are held in place with a spring behind the glass. just push the mirror in and remove the plastic bezel.
