External Door Hinges
2 replies to this topic
#1 Vanman20
Vanman20
  • 274 posts
Posted 15 October 2020 - 11:42 AM
There's some play in my door hinges.
I see you can buy a repair kit where you drill them oversize and insert a brass bush and a new pin.
Could you not simply insert a roll pin or would that not be strong enough ?
#2 bpirie1000
bpirie1000
  • Area Managers
  • 2,376 posts
  • Local Club: Amoc
Posted 15 October 2020 - 04:43 PM
You could....
In fact you could engineer any sort of hinge.
Have seen some soooper lightweight ones racer style of late. Just depends on the style of mini your after.
#3 KTS
KTS
  • 2,462 posts
Posted 16 October 2020 - 07:59 AM
the bush is needed to stop the pin wearing through the hinge body
fitting oversize bushes should only really be necessary if the pin has worn through the existing bushes and into the hinge so the hole is no longer round
