Bonnet Buffers
7 replies to this topic
#1 DUF2
DUF2
    Formally known as DUFfi
  • 456 posts
  • Local Club: Whickham & DMC
Posted 21 October 2020 - 02:05 PM
I have recently bought some bonnet buffers 14G6856 from Somerford Mini. The rubber is so hard, they are almost impossible to fit into the holes on the slam panel.
Has anyone else had this problem?
How did you get over it?
#2 KTS
KTS
  • 2,441 posts
Posted 21 October 2020 - 02:42 PM
yep - i struggled to get them to fit
i resorted to using a junior hacksaw blade to carefully abrade away some of the material around the 'stem' so i could get it to fit.
#3 Johnmar
Johnmar
  • 172 posts
Posted 21 October 2020 - 02:48 PM
Does they get softer enough if you drop them for 15 minutes in water that has just boiled (but is ot longer boiling)?
#4 DUF2
DUF2
  • 456 posts
Posted 21 October 2020 - 03:09 PM
I tried heating them with a hot air gun, but they didn’t soften any. They were then a bit too hot for my fingers!
#5 sheldon1992
sheldon1992
  • 20 posts
Posted 21 October 2020 - 04:28 PM
I used the new adhesive ones instead.
#6 DUF2
DUF2
  • 456 posts
Posted 21 October 2020 - 04:35 PM
Done it!
i used a bit of emery folded to sand the top bottom & middle of the groove, the dropped them in boiling water for a few minutes and managed to get them in.
thanks for your help folks.
#7 burchy35
burchy35
  • 114 posts
Posted 21 October 2020 - 05:57 PM
Glad you sorted it.
It's one of those jobs that should only take a couple of minutes but end up taking a good couple of hours ?
#8 steeley
steeley
  • Just Joined
  • 623 posts
Posted 21 October 2020 - 06:03 PM
Don’t they all
