Jacks
18 replies to this topic
#1 I hate Brian
I hate Brian
  • 782 posts
Posted 21 October 2020 - 05:03 PM
What's the best jack to keep in the boot just in case (except the usual mini jack supplied) ? bearing in mind only 140 -150mm clearance at the front from ground
Edited by I hate Brian, 21 October 2020 - 05:04 PM.
#2 Maccmike8
Maccmike8
  • 1,101 posts
Posted 21 October 2020 - 05:21 PM
Scissor?
#3 Dusky
Dusky
  • 5,322 posts
Posted 21 October 2020 - 05:38 PM
Small bottle jack. Easiest and lightest.
#4 Spider
  • 15,684 posts
Posted 21 October 2020 - 05:40 PM
I too have usually found a Scissor type Jack as one type that seems to have a better chance of getting under our cars, but in considering that, you might want to take in to account a further drop in height with a flat tyre. I recall the standard Moke Jacks, they'd fit under fine - until you had a flat !
I also wouldn't be too quick to loose the standard Mini Jack.
#5 Maccmike8
Maccmike8
  • 1,101 posts
Posted 21 October 2020 - 05:47 PM
There is a mini one on ebay for £200  :D
#6 sonikk4
sonikk4
    Twisted Paint Polisher!!!
  • 16,168 posts
  • Name: Neil
Posted 21 October 2020 - 06:01 PM
There are low entry light weight trolley jacks if you don't mind having that floating around in the car.
https://www.machinem...inium-racing-j/
#7 cal844
cal844
  • 9,713 posts
  • Local Club: TFMOC
Posted 21 October 2020 - 06:04 PM
I use a scissor jack with 100mm closed size and that can lift the wheel to 2x tyre depth.
#8 nicklouse
  • 18,998 posts
Posted 21 October 2020 - 06:36 PM
It all depends on what you plan to use it for. Add a bit of wood to give more clearance.
#9 mini-mad-mark
mini-mad-mark
  • 921 posts
  • Local Club: northants wot no brakes
Posted 21 October 2020 - 08:49 PM
I found a really short scissor jack, around 8 or 9 inches long, for 3 quid at a car boot sale (remember those, before the pandemic....) and got a folding handle on ebay for around a fiver.
It closes to around 3 inches (75mm) but will get the wheel off the ground fully extended - being so short it fits in a little tool bag I carry for most journeys, with the minimum journey tool kit (tool box for longer trips - a topic in itself on here I think)
Depends what you're planning to do at the side of the road (I wouldn't want to do too much other than change a wheel unless I had to and so wouldn't carry anything bigger/heavier most of the time)
Maybe on a really long trip I would have one of those aluminium/alloy trolley jacks with low entry (haven't done a really long trip but I was planning to go to the IMM this year...... :angry:  :(
Do you want to carry something as well as a standard jack or instead of ?
#10 cal844
cal844
  • 9,713 posts
  • Local Club: TFMOC
Posted 21 October 2020 - 09:31 PM
I bought a 2 tonne scissor jack from Ebay, then welded a 100 mm length of 50x50 box section that I cut one side out of.
https://www.ebay.co....30AAOSwGhVfGAXo
Something like this but with a 50 mm c section welded on top specifically to prevent the jack from slipping as much as a trolley jack could.
#11 I hate Brian
I hate Brian
  • 782 posts
Posted 22 October 2020 - 07:05 AM
Cheers for the replies gents, possibly the scissor jack but I did see some low entry bottle jacks by SGS
#12 SolarB
SolarB
  • 1,406 posts
Posted 22 October 2020 - 07:53 AM
Can a bottle jack match the closed/open dimensions of a scissor jack?
#13 GraemeC
GraemeC
  • 7,467 posts
Posted 22 October 2020 - 08:08 AM
Usually one or the other, rarely both.
Of course they can usually lift much heavier things, but that's not overly relevant here.
#14 expat_cat
expat_cat
  • 32 posts
Posted 22 October 2020 - 08:39 AM
For the problem of height/clearance with a flat:
Consider the huge expense of also carrying a thick plank/wide-block of wood in the car.   :-)  (only needs to be 20-30cm long, 5-10cm thick)
You can then drive the flat tyre up onto it, winning back the lost clearance.
If you are really feeling creative, you could shape it like a small ramp!
#15 Maccmike8
Maccmike8
  • 1,101 posts
Posted 22 October 2020 - 08:51 AM
Im intrigued to see your jack?
