Electrical Problem..help!
12 replies to this topic
#1 Ckmac1995
Ckmac1995
    Starting My Mini Up
  • 4 posts
Posted 25 October 2020 - 03:02 PM
Been doing quite a bit of work on my Austin mini 1988 1000 city e auto and all electrics were working fine however now no electrics work other than headlights and high beam. I think it occurred after hitting the steering wheel when removing it. No fuses have blown and earths seem to be okay but feel like I’m missing one somewhere and I’m stuck. Any help or suggestions where to look?
#2 bpirie1000
bpirie1000
  • Area Managers
  • 2,571 posts
  • Local Club: Amoc
Posted 25 October 2020 - 03:44 PM
Does the car start?
Main relay as you look into the engine bay is located on the left hand side near the large front subframe mounting bolt.
Seen them cause the same problems you describe.
If it starts sounds like a wire on solenoid has come off which feeds the fuses.
#3 Ckmac1995
Ckmac1995
    Starting My Mini Up
  • 4 posts
Posted 25 October 2020 - 03:50 PM
Yeah car starts with no problems however now I have just realised the back lights don’t work either. I will have a look at the connections on the solenoid see if something has been disturbed there. Thank you for the reply!
#4 Tornado99
Tornado99
  • 750 posts
Posted 25 October 2020 - 04:16 PM
My 88 recently had a spate of eletricky issues appear within a few hours of each other. First, no radio and turn signals, then no starter solenoid click with ign key to start position, then no brake or rear lamps.
Starter relay terminals were de-corroded and starting came back. Checked the four fuses by removing and reinserting. Solved one isse but created another. Took each fuse box connector off a bd found the dreaded green corrosion on some contacts. Hit with rust converter (vinegar works well apparently) and wire brushed. Seems to have resolved all issues.
#5 mini-mad-mark
mini-mad-mark
  • 926 posts
  • Local Club: northants wot no brakes
Posted 25 October 2020 - 05:51 PM
+1 for checking solenoid - I ripped the dash out of my car a couple of times before I found a broken wire at the solenoid (but it started OK)
#6 steeley
steeley
  • Just Joined
  • 623 posts
Posted 25 October 2020 - 06:46 PM
Get yourself one one these
Easy to use to trace most faults
Attached File  66E2EB6B-BDEB-400A-965C-488EF4C6A27A.png   190.26K   5 downloads
#7 jime17
jime17
  • 948 posts
  • Local Club: None
Posted 25 October 2020 - 07:20 PM
The headlights are the only electrical item that isn't fused. Therefore as they work and nothing else does I'd start looking at the fuse box.
Edited by jime17, 25 October 2020 - 07:21 PM.
#8 Ckmac1995
Ckmac1995
    Starting My Mini Up
  • 4 posts
Posted 26 October 2020 - 05:45 PM
All sorted. Thank you all!
#9 jime17
jime17
  • 948 posts
  • Local Club: None
Posted 28 October 2020 - 03:11 PM
What was it in the end. It might help others one day.
#10 Ckmac1995
Ckmac1995
    Starting My Mini Up
  • 4 posts
Posted 28 October 2020 - 03:56 PM
Was two things, the connection on the solenoid was a bad connection, cleaned this up then found that power was going through some fuses but not others, found when I pushed the fuses in more it worked so ordered a new fuse holder so it would hold the fuse securely and worked perfect. Now however the left indicator doesn’t flash and just stays on, any ideas what could be causing this? Hazards and right indicator working fine?
#11 cal844
cal844
  • 9,736 posts
  • Local Club: TFMOC
Posted 28 October 2020 - 04:22 PM
Flasher relay or a bad earth on the left side
#12 jime17
jime17
  • 948 posts
  • Local Club: None
Posted 28 October 2020 - 08:10 PM
Bad earth would be my first thought too.
#13 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 28 October 2020 - 08:52 PM
As said above bad earth suspected, test if you have a sealey type tester and can provide a new earth, or make up a wire to the bulb holder to a good earth point to test.
Check in the bulb holder inside as they can cause the same issue of a bad earth
Edited by KernowCooper, 28 October 2020 - 08:53 PM.
