How To Change Mpi Forward Facing Oil Filter?
6 replies to this topic
#1 adamemmott
adamemmott
    Starting My Mini Up
  • 2 posts
Posted 26 October 2020 - 07:56 PM
Hi all,
I have just recently bought my first ever Mini, a year 2000 W Reg mini cooper but I have noticed the oil filter sits at the front facing forward, sitting at a 90 degree angle.  It has a cooling pipe ( I think) coming across the front on the oil filter too.
So im just looking for advice about how I change this filter.  Do I need to disconnect the pipe and therefore replace the cooling fluid each time??
last thing is the sump plug a magnetic plug and what oil should I refill with as I have seen a few different answers online so far.
Thanks in advance for taking the time to read this and all the advice, im sure I will be on here asking lots haha
Adam
#2 RedRuby
RedRuby
  • 1,201 posts
  • Local Club: No
Posted 26 October 2020 - 08:18 PM
You do not need to remove cooling pipe, although you may find it helpful removing the front grill. Can’t remember if the sump plug has a magnet on it. Recommended oil is usually 20/50 if it is a manual box.
#3 mpialan
mpialan
  • 118 posts
Posted 26 October 2020 - 08:26 PM
I remove the Coil Pack to give easier access to the Filter, some may say it is not necessary but, otherwise it can be a faff.
#4 Steve220
Steve220
  • 5,084 posts
  • Local Club: BMC
Posted 26 October 2020 - 08:28 PM
You can replace it by just pulling the pipe out the way.
#5 cal844
cal844
  • 9,671 posts
  • Local Club: TFMOC
Posted 26 October 2020 - 09:29 PM
Remove the coil pack and lift it ontop of the engine.
Wash the spills off the engine once you fit and tighten the oil filter, I just use petrol or brake clean. Remember to smear some fresh oil onto the sealing ring.
Sump plug should have a magnet on the end.
Use 20/50 mineral oil, I use Comma classic but change every 3000 miles. Or use valvoline VR1 which is more expensive but better than the comma stuff.
Hope this helps.
#6 Quinlan minor
Quinlan minor
  • 1,220 posts
  • Local Club: LSMOC
Posted 26 October 2020 - 10:01 PM
I've never experienced any problems removing the oil filter on my MPi. I drain the sump before I remove it. Unscrew it and slide it out, hole upwards, then drop the new one down, hole upwads, lift into position, then screw on.
#7 adamemmott
adamemmott
    Starting My Mini Up
  • 2 posts
Posted 27 October 2020 - 07:12 PM
Amazing thanks for the help
