Throttle Position Sensor Open And Clean Up
11 replies to this topic
#1 hungdynasty
hungdynasty
  • 179 posts
Posted 30 October 2020 - 01:58 PM
I took advice of japanese friend owners, open the TPS to inspect and do some cleaning up. My TPS condition is actually pretty good, a bit carbon dirt but all other metal pins and resistance board are all good, pictures for your reference. If you want to do it , just cut through the edge of the top "cover", you will feel it if you have cut through the glue, it took me 2 hours. Then use a small screw driver to pop the cover up, you will see the resistance board, cut the glue on the top and bottom edge and it can be pop up.
#2 MatthewsDad
MatthewsDad
  • 901 posts
Posted 30 October 2020 - 05:04 PM
Interesting! Thanks.
#3 brivinci
brivinci
  • 1,225 posts
Posted 30 October 2020 - 10:38 PM
Extremely interesting as these are hard t come by these discontinued, no? If I have a spare, I might have to give this a go.
Thinking: lets say you do get into this, how best to clean it? The DeLorean had these terrible rear light circuit boards that always corroded and we used to use a pencil eraser to clean them up. I'd have to imagine there is a better method then that these days! ha.
Edited by brivinci, 30 October 2020 - 10:43 PM.
#4 hungdynasty
hungdynasty
  • 179 posts
Posted 31 October 2020 - 05:07 PM
I think it's discontinued, and probably no more new part available. Japanese mini owners do have some options to get a modified TPS and I think if you are a good DIYer you can modify yourself, just get an aftermarket sensor and make an adapter to install. The mini factory sensor is turning clockwise if you look at the manifold side, see picture.
#5 pakgorgor
pakgorgor
  • 91 posts
Posted 03 November 2020 - 11:42 PM
What does a dirty one look like?
#6 brivinci
brivinci
  • 1,225 posts
Posted 03 November 2020 - 11:55 PM
I have seen an adapter sold in Japan that lets you use a later/easier obtained TPS. At least there are options out there.
#7 hungdynasty
hungdynasty
  • 179 posts
Posted 04 November 2020 - 04:15 AM
https://images.app.g...PBbgWZoVsjgjBf9
Google translate this Japanese pages and you will see a lot.
#8 brivinci
brivinci
  • 1,225 posts
Posted 04 November 2020 - 03:56 PM
Thanks for the link. This is the kit I remember seeing a bit ago.
https://page.auction...tion/s775181088
#9 FlyingScot
FlyingScot
  • 2,676 posts
Posted 07 November 2020 - 09:50 PM
Electrical contact cleaner spray or methylated spirits on an cotton earbud to remove the loose worn material.
Based on current experience worn TPS is becoming a bigger issue as spiking voltage input confuses the MEMS ECU and few NOS parts left.
FS
FS
#10 Bobbins
Bobbins
  • 1,526 posts
Posted 07 November 2020 - 11:02 PM
Is this a direct replacement from Japan?: http://classicminisj.../potentiometer/
#11 Ade-Cooper
Ade-Cooper
  • 125 posts
Posted 10 November 2020 - 03:43 PM
WOW £200 isn't cheap mind
#12 FlyingScot
FlyingScot
  • 2,676 posts
Posted 16 November 2020 - 10:39 AM
Yes but I guess it makes it easier for any future replacements...
FS
