Steering Rack Play - Is The Worn Or Ok?
26 replies to this topic
#1 will_nic
will_nic
  • 102 posts
Posted 05 November 2020 - 04:26 PM
As the title says, I've had a little bit of a knocking sound coming from the front LHS of the car occasionally when going over bumps. There's a bit of play in the LHS of the steering rack. Is this normal or worn?
Cheers.
#2 cal844
cal844
  • 9,625 posts
  • Local Club: TFMOC
Posted 05 November 2020 - 05:26 PM
That's worn needs rebushed. I'd refurbish it personally
#3 slidehammer
slidehammer
  • 1,196 posts
  • Local Club: LSMOC
Posted 05 November 2020 - 05:51 PM
I would check the rest of it over for play and if you find more wear on the other side I would just replace it with a new one.
#4 will_nic
will_nic
  • 102 posts
Bummer.. Looks like a hassle to get the rack out huh?
Is this the bush that would be worn?
http://www.minispare...ck to catalogue
Cheers.
#5 will_nic
will_nic
  • 102 posts
Posted 05 November 2020 - 05:52 PM
There's no play on the other side, as far as I can tell.
New racks dont seem that expensive...
#6 slidehammer
slidehammer
  • 1,196 posts
  • Local Club: LSMOC
Posted 05 November 2020 - 05:56 PM
I agree, by the time you have bought new rubber boots etc, best you just replace the lot
#7 Spider
  • 14,946 posts
Posted 05 November 2020 - 06:28 PM
They aren't difficult to overhaul and often all that's needed is the Bush and Gaiters.Some of the new racks aren't too brilliant and seldom last.
There's a how to guide on overhauling the Rack here;-
http://www.theminifo...l-uk-type-mkii/
#8 will_nic
will_nic
  • 102 posts
Posted 06 November 2020 - 03:06 PM
Thanks!
I think I'll try get the rack out (this looks like by far the hardest part!) and assess. Thanks for the help.
#9 Maccmike8
Maccmike8
  • 1,101 posts
Posted 06 November 2020 - 04:51 PM
Keep us updated.
#10 will_nic
will_nic
  • 102 posts
Posted 06 November 2020 - 05:57 PM
Didn't get much time in the garage today, but did have a better look at getting the rack out and pre soaking all the bolts in penetrant.
I did have a better look at the other side of the rack. With it at full lock (fully extended) there is play on the RHS as well... not as much as the LHS but still some.
To be honest, I'd rather just buy a new, clean steering rack and fit it rather than rebuild mine, but if the quality of the replacements for sale at MS arent as good, I will rebuild. Any thoughts?
Cheers.
Edited by will_nic, 06 November 2020 - 05:58 PM.
#11 will_nic
will_nic
  • 102 posts
Posted 21 November 2020 - 10:08 AM
Well, got the new rack in and the difference is night and day. No more knocking sounds and the steering feels so much tighter. Actually didnt take as long as I thought to install - two afternoons from start to finish.
Pic from a quick test drive afterwards.
#12 Maccmike8
Maccmike8
  • 1,101 posts
Posted 21 November 2020 - 10:53 AM
It really suits the black steelies and wing mirrors  :shifty:
#13 will_nic
will_nic
  • 102 posts
Posted 21 November 2020 - 11:01 AM
Thanks! I've got a set of split rims for it which I haven't got round to painting because I like the steelies!
#14 Maccmike8
Maccmike8
  • 1,101 posts
Posted 21 November 2020 - 11:07 AM
Got any more pictures?
#15 will_nic
will_nic
  • 102 posts
Posted 21 November 2020 - 11:50 AM
 Here's a couple. There are a few more on my IG @will_nic
Edited by will_nic, 21 November 2020 - 11:51 AM.
