will cooper s brakes fit on standard disc hubs
9 replies to this topic
#1 lew
lew
  • 643 posts
  • Local Club: mmm
Posted 31 October 2006 - 09:32 PM
as it sais in the title will they fit onto standard disc brake hubs
#2 Dog
Dog
    Deathwish Fairy
  • 9,550 posts
  • Local Club: Shatrats.com
Posted 31 October 2006 - 10:01 PM
Should do!
as all your changing is the disk....
then the caplapers suit the disk...
AFAIK....!
#3 fikus01
fikus01
  • 1,910 posts
  • Local Club: SMAG - Southend Mini Action Group
Posted 31 October 2006 - 10:31 PM
to change the discs to 7.5" you need the cooper drive flanges too!!
ooh another thought!! i think the cooper hubs ran the same steering arm as drum brake models!! different turning leverage for the 10" wheels but this in not essential i dont think!!
#4 Dog
Dog
    Deathwish Fairy
  • 9,550 posts
Posted 31 October 2006 - 10:35 PM
Well the brakes hes on about are mine...
they will come with;
Calapers
Flanges
disks
rebuild kits...
I am guessing this is all you need to change from 8.4" disks to 7.5"
#5 fikus01
fikus01
  • 1,910 posts
Posted 31 October 2006 - 10:42 PM
check that steering arm thing out!!
#6 minidaves
minidaves
  • 4,933 posts
  • Local Club: mine
Posted 31 October 2006 - 10:56 PM
more important make sure you get the discs with the insdie machined rather than square else they dont rotate
dave
#7 syholl
syholl
  • 710 posts
Posted 01 November 2006 - 07:47 AM
I fitted 7.5" disc brakes to our Woody estate, using the hubs and steering arms off a later 8.4" set up. Not had any problems at all, tire wear is even, no bump steer or tramlining....
#8 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 01 November 2006 - 08:00 AM
there is no difference between an S hub and a MK4 hub....nor on the steering arms
#9 miniboo
miniboo
    Lord of Original Thinking
  • 9,327 posts
Posted 01 November 2006 - 12:06 PM
S steering arms are thicker though aren't they?
Also S hubs have a taper and mk4 hubs have a step.
but both types of discs fit.
#10 Dog
Dog
    Deathwish Fairy
  • 9,550 posts
Posted 01 November 2006 - 01:50 PM
the early cooper s, shared the same drive shafts as the early auto's!
so all in all, these will fit Lew's car :P
