998 Engine Build To Sell
23 replies to this topic
#1 Project_1275_GT
Project_1275_GT
  • Just Joined
  • 341 posts
Posted 07 November 2020 - 12:51 PM
Hi
I have started a project on here for the rebuild of my 998 A plus engine and box. I have calculated the realistic cost for the rebuild and adds up to £2392.49 without really charging for labour. So i guess final selling cost will be £2800 to allow for time and effort along with all the materials not included in my costings like paint, oil, grease etc.
Here is the question? Is there really a market for a 998 engine for this money? I have listed a spec below and would like peoples opinions
998 A plus +20 re board
New Hepolite pistons and ring set
chemical clean
original con rods [bead blast]
new oil gallery plugs
new cam bearings
new evo 1 cam
new main bearings
new big end bearings
New oil pump [slot drive]
All clearances checked
repainted
oil filter housing blast and ACF50
new oil filter
compression ration checked
standard head for 998 chemical clean and bead blast [unleaded valve seats]
new rocker shaft
new rocker springs
original valves lapped
original spring set
new oil seal
new head gasket
MG alloy finned rocker reconditioned with new cap
silicone gasket
new thermostat and reconditioned housing + gaskets
new temp sensor
3.44 final drive A plus gear unit - glass blast and sprayed with ACF50
all new RHP bearings
new needle bearings
comp lay shaft
comp baulk rings
X pin diff
new springs and bearings
new gaskets
original gear set checked ok
glass blast transfer housing - new bearings - idle gear shims set
AP pressure plate and clutch plate
Standard flywheel
primary gear correctly gapped
New distributor Evo from mini spares [electronic]
new sports coil
new plug leads and plugs
New alloy inlet manifold
Reconditioned HS4 carb with new AAU needle
K&N cone filter
New fuel pump [mechanical]
Cooper free flow exhaust
all gaskets etc
all required brackets and mountings
The unit will be pretty much ready to drop in and start driving. But the biggest question is ..
Does anyone value this at the above cost? Really not trying to do this for huge profit. Going to be at home for a few months, had the engine and many parts already laying around. Just thought it would be nice project to build and sell on. But at near £3000 i am wondering if anyone would spend the money on a 998 or simply by a 1275.. The build spec should be classed as at least stage 1 and the gearbox would allow much more room for power. If someone really wanted to make it quicker they could change the head to 12G295 and have it flowed. Ive probably missed some items off on the rebuild list. its quite extensive.
Any thoughts welcome
thanks
#2 luismx123
luismx123
  • 525 posts
Posted 07 November 2020 - 02:09 PM
hmmm difficult to say. at 3000 id look into getting a 1275 thats been upgraded, and i know lots would too. it costs the same to do a 1275 or 998. and with a tuned 998 like your plan, youll be just passing 1275s in standard form.
#3 johnv
johnv
  • 498 posts
  • Local Club: FDMC
Posted 07 November 2020 - 02:14 PM
The buyer will need to trust that you have put it together properly. You will have to trust that the buyer installs and treats it properly.
what if something goes wrong?
But .. nice engine and worth the money to the right buyer!
Edited by johnv, 07 November 2020 - 02:16 PM.
#4 Project_1275_GT
Project_1275_GT
  • Just Joined
  • 341 posts
Posted 07 November 2020 - 02:27 PM
Thats sort of my thinking. Seems a shame to not complete what i have started. But I do wonder how many people would actually want it.
#5 Project_1275_GT
Project_1275_GT
  • Just Joined
  • 341 posts
Posted 07 November 2020 - 02:29 PM
This is also a concern. I have been posting the progress so far. I do intend to show all build detail and costs. But your comment of correct install and treatment from buyer does also worry me.
#6 Project_1275_GT
Project_1275_GT
  • Just Joined
  • 341 posts
Posted 07 November 2020 - 02:32 PM
As I already have most of the main components I might build each section and sell.
Carb with K&N
Head
Short block
Gearbox
Just a little concerned i will build something that is good but not really wanted. Sure the separate sections will sell on ebay
#7 Turbo Phil
Turbo Phil
  • 2,426 posts
Posted 07 November 2020 - 03:43 PM
There’s not a huge market for 998’s and at nearly 3k for a basically standard engine I think you’d struggle to sell it.
Phil.
#8 dyshipfakta
dyshipfakta
  • 1,696 posts
Posted 07 November 2020 - 04:10 PM
It’s a labour of love you will never get your money back. If you not going to use it I wouldn’t bother.
#9 Project_1275_GT
Project_1275_GT
  • Just Joined
  • 341 posts
Posted 07 November 2020 - 04:15 PM
Phil.
This is the problem. The gearbox rebuild costs a fair amount of the money. But when you put the 998 on top it makes it all seem expensive. I would not really be prepared to cut any corners building it. wouldnt make sense.
#10 Project_1275_GT
Project_1275_GT
  • Just Joined
  • 341 posts
Posted 07 November 2020 - 04:20 PM
The time is not really an issue. I will be house bound for the next 3 month. I will be able to sit and build the engine to prevent myself being extremely bored. But it will cost best part of £3000 and i dont really see a huge market for the 998 engines. its a shame really.
first mini was a 1098 clubman - loved it
second was the 1275 gt im still working on...
third was a 998 - loved it
I really liked the small engines. but not worth time and money if no one wants it
#11 Maccmike8
Maccmike8
  • 1,101 posts
Posted 07 November 2020 - 05:10 PM
I wouldnt drop 3k on any engine if not from a reputable builder or at least test driven in a running car.
#12 Project_1275_GT
Project_1275_GT
  • Just Joined
  • 341 posts
Posted 07 November 2020 - 05:45 PM
That seems to be the problem. To rebuild correctly the parts cost a lot of money. Just does not seem viable to build. I just dont think people will be prepared to pay what it actually cost
I built my turbo engine and did not add it up. Im sure the final cost would have been over double that of the 998 build. Maybe more.
Looks like i will continue to build but sell as separate parts.
#13 sonscar
sonscar
  • 3,047 posts
Posted 07 November 2020 - 05:46 PM
To my jaundiced eye any engine from a private seller is only suitable for a rebuild,you may be an excellent engineer but what if a new part fails?£300 tops.Just my cynical view.Steve..
#14 Project_1275_GT
Project_1275_GT
  • Just Joined
  • 341 posts
Posted 07 November 2020 - 05:57 PM
Again this seems to be the general consensus. Looks like I will continue with the refurb of all parts I have, then just sell the individual items. If I build it it costs a lot more. Seems crazy that the 998 engine is not that favoured. I really enjoyed driving mine
#15 Maccmike8
Maccmike8
  • 1,101 posts
Posted 07 November 2020 - 06:00 PM
Build it, use it and then in a year or 2 sell it to me for £1k wink wink.
